Old 09-03-2015, 04:41 PM   #2
ianacole
Brake light switch? Right side works, so wouldn't be that...
Are the lefts on an independent circuit and fuse? If so, check for power there... replace the fuse with a tested good while there, even if the original looks good.
Check the harness behind the light housing to see if you're getting voltage there...
ianacole is offline   Reply With Quote
