06-25-2015, 10:22 PM
#1
spark plugs-help
Hi Guys,
I want to change my spark plugs (00' 986 S)
-what are the best plugs to buy and where?
-where can I find the best instructions for the process?
thanks!
de-snorkeled, clear lights, sports exhaust, zeintec hard top, zein wing, B&M short shifter, DesignTek lowering springs, DesignTek carbon fibre strut brace front and rear, 18'' carerra 5 spokes, semi slick tyres, entire soft top delete, engine cover delete,red console,L&N deep sump, volo performance chip, raptor shift light, de-cat'ed, OEM GT3 bucket seats.
06-26-2015, 01:52 PM
#3
Make sure you have a local source for the tubes before you start.Some may be leaking/cracked.
Make/buy a tool to extract the tubes .Bolt+washer is the best IMHO.Details in Search.
You also need a very reliable ,small, click or beep torque wrench - be very careful not to overtorque .No anti-seize ! I use an aircraft mechanics 1/4" drive.
Inspect the coil packs with a lens after you have cleaned them thoroughly- look for small hairline cracks.
Number the H.T. leads - easy to muddle some of them.
06-27-2015, 07:33 AM
#4
Thanks for the advice, would replacing the tubes+ O-rings not be a good idea for peace of mind?, I see they are not too expensive. And what about the plug connectors, are these prone to deteriorate?
thanks!
06-27-2015, 02:18 PM
#5
Look for oil leakage around the tubes. If it is dry,leave well alone.
Connector is part of the coil.Cracks are the issue to check for on the coil.
06-29-2015, 11:04 AM
#6
plugs
Pedros Porsche DIY site has an excellent tutorial on changing the spark plug tubes.
06-30-2015, 12:40 PM
#7
thanks for all the good advice. I will do a thorough inspection of all parts for defects, it seems this is key. Once I have tackled the job, I post on how difficult i thought it was.
