06-11-2015, 05:06 PM
Building a 3.2L
Hi There!
I am a new owner of a 2002 base Boxster with 103,000 miles, but in great condition.
I am looking at building up a 3.2L Engine to replace the 2.7. The car is an automatic transmission - my question is: Does the donor Engine I am going to start with have to come from original Automatic Car? or does it not matter if it was a Manual transmission car? Are the blocks the same?
2002 Porsche Boxster Carrara White - 103,000 miles
06-11-2015, 05:22 PM
build a v8!
06-12-2015, 06:11 PM
Originally Posted by 78F350
Yes! I did pick up the book, just didn't get the chance to go thru it yet.
06-11-2015, 07:23 PM
Need For Speed
I would sell it and buy one with a 3.2l engine in it.
06-11-2015, 07:33 PM
3.8. Done.
06-11-2015, 08:30 PM
Need For Speed
Originally Posted by JAAY
3.8. Done.
Even doing this I would start out with an S model. There is more to the S then just a 3.2l engine.
06-12-2015, 07:42 AM
Yes, the brakes and suspension are "better".
But I had more legal fun in my 2.5 than my 3.2.
06-12-2015, 09:38 AM
Huh? You're not making any sense at all...
06-13-2015, 03:50 AM
Need For Speed
We already know the S has better cooling too and according to Renegade Hybrids it has a better drivetrain.
https://youtu.be/P67OSN2DqAE?t=409
06-12-2015, 09:00 AM
Engine Surgeon
Or just build a 3.6/3.8/4.0/4.2 from your OEM 2.7 core
Yes, I can.
US Patent 8,992,089 &
US Patent 9,416,697
06-12-2015, 03:42 PM
Yes, I can.
What can you build from a 3.2?
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
06-12-2015, 08:34 PM
Engine Surgeon
Originally Posted by porsche9
what can you build from a 3.2?
3.5, 3.6, 3.8, 3.9, 4.0, 4.1...
US Patent 9,416,697
06-14-2015, 06:00 PM
Jake - sent you a PM.
06-14-2015, 04:19 PM
Originally Posted by Boxy_02
Hi There!
The harness from your motor will work with a 3.2 motor just swap it.
The vacuum system tubing can be moved to the donor engine as well.
Any similar year 3.2 motor will swap into a 2.7 car.
I have a 3.2 block from a tip running in a 2.7 manual chassis. You can pick up front S brake calipers on Ebay for cheap and replace the rotor for about the same price as new non-S rotors and brakes. Rear brake let alone same pads S or non-S.
Good luck have fun.
06-14-2015, 08:42 PM
inveniam viam aut faciam
I want to hear the reaction when he sees Jake's cost to make a 3.6...
