05-23-2015, 05:50 AM
AOS Delete
As anyone deleted there AOS, ie blanked off the throttle body and run a pipe from the top of the AOS to a catchment tank/can.
l replaced my startermotor a few weeks ago and found a fair bit of oil in the pipe
between the throttle body and AOS, but i wasn't getting any smoke bombs while
running just the odd puff of blue smoke if reved hard at standstill and when the wife
followed me it did smoke a little but nothing major
Anyway clean out the pipework fitted a new AOS done 300 miles just checked
the pipe and there oil in there again.
Have seen posts on here where a guy had 3 duff one's straight from the box think
it was one of jake's post.
So has anyone deleted theres, if so has there been any performance loss
with the crankcase not being under vacuum
05-23-2015, 06:19 AM
Need For Speed
What year is your car?
2003 Boxster S
05-23-2015, 06:29 AM
1998 with a 3.4 996 motor
05-23-2015, 06:30 AM
Need For Speed
What year is the motor?
2003 Boxster S
05-23-2015, 06:40 AM
Need For Speed
I have stuff to do. Check this if it corresponds to your engine.
Crankcase Ventilation Valve
In some cases the ventilation valve on the valve cover that connects the crankcase to the oil seperator becomes clogged, and may cause problems for the oil seperator. If your newly replaced oil seperator is starting to fail, or you are about to install a new seperator, you might consider replaceing the ventilation valve.
Pelican Parts - Product Information: 996-107-047-51-M100
2003 Boxster S
05-23-2015, 06:54 AM
I've seen that valve its on bank 4 to 6 AOS pipe did wonder what it was, can it be cleaned
05-23-2015, 07:03 AM
Piston ring tension is affected IIRC. You don't want that
986 00S
05-23-2015, 08:43 AM
The low tension piston rings rely on the crankcase vacuum to help seal the rings, eliminating that vacuum increases blow-by. If the AOS is disconnected from the vacuum source no oil will come out the top of the AOS.
05-23-2015, 08:58 AM
Along with blow by and he loss of effectiveness for the low tension rings used in these engines, not having vacuum in the case sump will lead to increased water and fuel level build up in the oil as the low vacuum level created by the AOS helps to flash them off at lower temperatures. This will very quickly degrade any oil.
05-23-2015, 10:16 AM
Cheers for the replys lads, looks like I'll give that one a miss
05-23-2015, 12:31 PM
good reading
+ 1
Very interesting comments from BY and JFP
05-23-2015, 02:40 PM
A catch can needs to be plumbed inline between intake plenum & AOS.
05-23-2015, 10:53 PM
05-24-2015, 04:54 AM
Rennzenn
Or something like this
OK, here's where everyone tells me I'm killing my engine. I've run this for 3-4 years now and 25,000+ miles. So far so good. I think I did it as much to try an alternative solution as I did for a cheap easy fix. But it's just a race car, so what the hey. I would not do this to my everyday driver.
Rennzenn
Jfro@rennzenn.com
08-18-2015, 06:52 AM
Can you elaborate on how you've plumbed this in? I am looking to delete the AOS on my 986 racer (which is getting ITBs, so no real good source to hook up the AOS vaccuum line).
08-18-2015, 12:35 PM
Rennzenn
My "piggyback" AOS is plumbed in between the facatory AOS and the intake. I removed the plastic tube, threaded the AOS and the intake "T", adding brass hose fittings. I then mounted the piggyback AOS in the trunk and ran fuel line to connect it to both brass hose fittings.
Rennzenn
Jfro@rennzenn.com
09-29-2021, 06:41 AM
Resurrecting this post from a fellow 986 track driver, who gets the occasional blue puff of death.
Add $1000, the motor sports AOS solution seems to be overkill. Looking for a more pragmatic solution. Is your truck solution still working well? How often do you have to drain the oil from the bowl?
Much appreciated!!
09-29-2021, 08:11 AM
I run a 1 qt nuke performance catch can after disabling the stock AOS. I've added a vW regulator further down the line. This seems to work well and would cost you about $350. That said, I've deleted both my SAI and engine compartment fan to get space, so ymmv.
09-30-2021, 04:50 PM
I plumbed a $25 catch can between the AOS and intake. I wanted to leave the AOS as a regulator valve because redoing all the connections would be a pain to do. However, a good adjustable valve would only run another $25 (that way you can dial in the exact pressure you want).
I've run mine 5hie way for over a thousand miles. No issues. I've looked in there recently and have very little kerosene like residue.
