Thread: AOS Delete
Old 05-23-2015, 06:40 AM   #5
KRAM36
Need For Speed
KRAM36's Avatar
I have stuff to do. Check this if it corresponds to your engine.
Crankcase Ventilation Valve
In some cases the ventilation valve on the valve cover that connects the crankcase to the oil seperator becomes clogged, and may cause problems for the oil seperator. If your newly replaced oil seperator is starting to fail, or you are about to install a new seperator, you might consider replaceing the ventilation valve.
Pelican Parts - Product Information: 996-107-047-51-M100
2003 Boxster S
