03-23-2015, 09:59 AM
Third brake light change
How hard is it to change the high mounted brake light? I'd like to change the red one for clear plastic with red LEDs.
Randy
2002 Boxster Seal Gray Metallic: Desnorkled, Changed ashtray to non-smoker's bin, Removed stickers from sunvisors, Added rear speakers, LED Shifter, Porsche logo on trunk lid, New top with heated glass window, Aspheric Driver's Side Mirror Upgrade, More to come...
03-23-2015, 10:36 AM
Not difficult at all. Put the top in service position so the clamshell is out of the way to access the two screws that hold it down and unplug the harness. Reverse steps to install. Be aware that on some Boxsters the third light, tail lights and cruise control are all tied together in the fuse box. If you install LED tail lights along with an LED third light the current drops and the cruise control will not work unless you install a resistore at the third light.
03-23-2015, 11:40 AM
 Thanks!!
Randy
03-25-2015, 10:38 AM
Be very careful with the light more importantly the bits that hold the light on to the screws. Mine came off in the car and fell in the trunk behind the liner and 2 hours later I found them.
08-26-2015, 09:07 PM
Installing resistor at 3rd brake light
Where should the resistor be installed, can it
be close to the harness plug for the 3rd brake light?
08-28-2015, 05:36 AM
Be careful the resister gets hot. Attach it somewhere where heat isn't an issue.
08-28-2015, 06:21 AM
Yes if there is room for it and heed emore93's advice.
08-30-2016, 03:47 PM
I am new to this forum. And see this older post . The two rubber cylinders that hold the third lite in place fell into the lower space and I would appreciate any help in how to retrieve them. Could not find in the trunk after removing the felt backing. Only the computers, etc. Am I looking in the wrong place? Thanks, Bill
08-31-2016, 09:11 AM
1999 base
you will have to "fish" it thru the holes in the frame.
08-31-2016, 09:59 AM
Just go buy two more. Cheap and less hassle!
09-01-2016, 07:43 AM
Beginner
I installed mine without a resistor and the cruise works fine.
2003 S manual
09-01-2016, 09:28 AM
What resistor size
09-01-2016, 01:55 PM
Thanks for the pic and info. I will try to fish...if not successful I will order a couple. No Porsche dealer in my little town!
Bill
2002 Boxster S
1991 BMW 850i
1971 MGB GT
And a couple of newer vehicles
09-06-2016, 10:09 AM
It seems I can't find them. Is there a trick to finding those rubber cylinders. Thanks, Bill
Bill
02 Boxster S
01 Carrera Cab
91 BMW 850i
71 MGB GT
09-06-2016, 11:07 AM
Like this in attachment? Item #14, pn 99950012800. In stock from the forum sponsor Pelican!
Rear Light License Plate Light M602 Additional Brake Light
09-06-2016, 12:15 PM
I'm tired of hunting. I'm going to buy them. Thanks for the help guys.
Bill
Bill
02 Boxster S
01 Carrera Cab
91 BMW 850i
71 MGB GT
09-10-2016, 05:41 AM
Just a tip for anybody who cares. I took tight grommets put them in the holes. with a drop of super glue, so they would not spin and after about a half hour, I drilled holes just big enough for the screws to go through and remounted the third light.
Bill
02 Boxster S
01 Carrera Cab
91 BMW 850i
71 MGB GT
