Not difficult at all. Put the top in service position so the clamshell is out of the way to access the two screws that hold it down and unplug the harness. Reverse steps to install. Be aware that on some Boxsters the third light, tail lights and cruise control are all tied together in the fuse box. If you install LED tail lights along with an LED third light the current drops and the cruise control will not work unless you install a resistore at the third light.
