Old 03-03-2015, 01:20 PM   #9
i'm not sure if the temperature sensor connects directly to the cluster, or goes Through the ECU.
i suggest you look at electric diagrams, as i assume you are not going to use the OEM ECU, but the V8 one.
what year is your boxster (and cluster)?
Its a 2000 Booster S. I will actually be using the Porsche ecu to run some stuff like the gauges, fuel pump, etc . I'll have to cut down the harness quite a bit of course.
martsink is offline   Reply With Quote
