Old 04-04-2006, 08:20 PM   #9
Originally Posted by stucatz
OK what am I missing? Disconnect the battery before changing a ground wire? If the wire is truly a ground wire what is the big danger?
Hi,
The Ground wire is just that - an electrical path to earth.
You need to disconnect the ground wire from the fuel filter and fit it to the new one to swap it.
It there's something shorting to ground, you could get a spark when you disconnect it - Fuel + Ignition Source, generally not a good thing. Disconnect the Battery and No Worries. Hope this helps...
Happy Motoring!... Jim'99
