Old 04-02-2006, 08:02 PM   #2
MNBoxster
Originally Posted by BadBoyS
Took the Belly pan off and found the fuel filter. Have to get the new filter tomarro. Any words of wisdom on the change out. Getting the old one out looks like its going to be pretty tight. Thanks in advance you any advice................... :dance:
Hi,
Be sure to loosen your Fuel Filler Cap and disconnect the Battery before removing the Ground wire on the Filter (make sure you have your radio code before you do). Also, have plenty of Rags and a catch bucket for the Fuel which will leak from the Filter and hoses. Other than this, it's pretty straightforward. Good Luck!...
Happy Motoring!... Jim'99
