Old 02-10-2015, 07:30 AM   #1
On the slippery slope
JayG's Avatar
New brake hardware ??
I'm about to replace my brake pads, do i need to replace the hardware as well?
2004 996 Targa Tip
Instructor - San Diego region
Old 02-10-2015, 07:44 AM   #2
steved0x's Avatar
The first time I took my pads out and put them back in, due to rotor swap, I reused the same hardware (fronts only and only one side because I then realized you don't have to take the pads out)
This past September/October I changed pads as part of the caliper paint/stainless brake lane operation, and I did use all new hardware, partly because I did not know how old the existing pieces had been on there. I used Centric brand, which was much (I mean MUCH) more affordable than the Porsche brand. I got them from Rockauto which shows the correct picture. You can also get from Amazon, but they do not show the correct picture. Each kit has the hardware to do both fronts or both backs. They were around $7.00 each.
Front hardware: 11737004
Back hardware: 11737008
Because it was so affordable, I would probably use new ones. If I have to take my pads out for any reason without doing a full pad change, then I would probably re-use the hardware.
I re-used the brake shims in the front, I just took them out and cleaned them up good, and then put them back in with the new pads (which I put some anti-squeal/glue type of stuff). My backs didn't have any shims, and so I reassembled without them (I could not find an aftermarket rear shim, and the OEM were sooooo expensive, and it looks some folks don't run them anyway)
Are you changing pads for track use?
Old 02-10-2015, 04:15 PM   #3
I will admit that I re-use my brake hardware and haven't had any problems.
But as Steve said, its so darn cheap so why not take out the extra insurance? I think he's convinced me to change my ways and replace everything on the next brake change.
Old 02-11-2015, 03:38 AM   #4
I don't unbolt the calipers, so no need to change them. To do this I ditched the OEM anti-squeal pads the fit up into the piston.
Old 02-12-2015, 06:18 PM   #5
rdass623's Avatar
generally I will reuse the old hardware unless it is deformed when removing or installing the components. I have never seen the hardware fail so I feel comfortable with reusing it.
2005 Porsche Boxster S, 2000 Porsche Boxster 2.7L Base, 2000 Mazda Miata LS Supercharged, 2010 Toyota Tacoma TRD Off Road
Previous Vehicles: 2005 Ford Mustang GT, 1986 Alfa Romeo Spider, 1971 Alfa Romeo GTV, 1999 Ford Mustang
1977 Toyota Celica GT
rdass623 is offline   Reply With Quote
Old 02-13-2015, 02:52 PM   #6
woodsman's Avatar
I clean and reuse without adding any goop. No problems.
