09-13-2016, 02:24 PM
#41
After the commute to and from work I'm hooked on the McMaster Carr spring.
09-13-2016, 03:29 PM
#42
Originally Posted by CraigM
Honestly, I just went with the one the guys at rennlist found. Looks like they did a lot of digging, I just did the ol' copy and paste. 3 1/2 inches instead of 4 if I remember right - you'd never know driving it.
PM your address if you want it, and no worries if you want to take some time and try to find a different one. I think that thread (linked somewhere in this one) had a few other options, but those that tried a few of them preferred this one.
if you could provide a part number and source this would be very useful.
09-13-2016, 03:36 PM
#43
McMaster Carr spring part number 9657k142
09-13-2016, 03:39 PM
#44
But you got that from a dubious source(me)?
"Based on the info above :-
The stock spring is 75lbs/inch and about 4" long
The McMaster Carr spring # 9657k142 is 39lbs/inch but only 3-1/2" long.
The deficiency in length is a problem?
If so, check McMaster Carr #9657K136.
This is slightly larger diameter(1.25" vs 1")
It is 57 lbs vs 39 (or 75lbs.for OEM)
Fully compressed it is longer than the short spring 2.81" vs 2.31" Is that 1/2" a problem?
You can buy just one spring in # 9657k136
or this?
http://www.ebay.com/itm/131476133178?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
15 16" O D x 4" x 0 148 Compression Springs Pack of 2 | eBay
09-13-2016, 04:00 PM
#45
It's the spring mentioned in the rennlist thread. They come from McMaster Carr as a bag of 6. It fits and it works, but I doubt I'm the only one who has tried it here so I'm sure someone else will weigh in.
I can't see how the longer compressed length can be a problem as the locking hole is visible with either spring in the compressed state. Wider might be a problem getting it into the canister. I didn't measure the canister while it was out.
09-26-2016, 01:28 PM
#46
I've read the whole thread but still dubious on what is being felt with the mod?
Is the clutch pedal going to be lighter to press in? or depresing faster?
09-26-2016, 02:07 PM
#47
Heavier pedal, less spring assistance. Better feel, easier modulation.
I found the original spring made for a very light pedal, (numb feeling), and I had a harder time finding the biting point than I should have.
09-27-2016, 03:45 PM
#48
Nice! I am in then!
CraigM, would you send one to me?
11-04-2016, 10:38 AM
#49
Just pulled the spring & I like the feel, though there is some play when the pedal is fully released.
Ordered a 6-pack of McMaster springs & will report back on my experience.
98 Arena Red 986
03-13-2018, 02:44 PM
#50
Got all psyched to pull the clutch spring assist from my semi new to me 98, stretched a bit and under the steering wheel I went. removed the vent to make things easier to
see................. that my spring assist is already removed. Some have complained about how hard the clutch is to push without it, I guess when one doesn't know the difference...... sure feels light to me
Dave
1998 Boxster
1978 R100RS BMW Motorcycle 140K, 1 owner
03-13-2018, 09:57 PM
#51
Dang.... SO glad this thread was raised from the dead. I thought I was loosing my touch or the Box's clutch pressure plate was ****************e... Just haven't been able to dial the feel of this thing! I just ordered springs. Let's see how it goes!
03-17-2018, 09:53 AM
#52
Yanked the overcenter spring on my winter VW MK5 too, made an impressive improvement there. No more vague pedal. I can’t see the reasoning for the overcenter spring. These cars don’t have heavy clutches.
03-17-2018, 04:05 PM
#53
Wow, a relatively simple thing can make such a difference! Installed the Mcmaster spring, took about 30min total, if that long. What a difference!
03-18-2018, 03:37 AM
#54
Ben-Auto-Design
The clutch power spring is a very good mod, especially on 2.5 and 2.7L which have a weird feeling from stock.
https://www.youtube.com/watch?v=YfjD4a_m900
ASE certified Automotive Master Technician.
Porsche Tech in France.
www.benautodesign.fr
Ben-Auto-Design : Performance parts for 9X6 / 9X7
1982 928 S Euro
03-18-2018, 05:45 AM
#55
550 Anniversary
I wonder whether you US people have a different spec springs or set up. Not many people complain about this over here. Indeed, the most common 'mod' is to replace a broken spring and most report a better clutch operation. Manual cars are the norm here and I don't notice anything particularly peculiar with the clutch in either of the Boxsters I've had compared to the dozens of other cars I've driven.
| Thread Tools |
| Display Modes |
Linear Mode
