Old 01-21-2015, 10:52 AM   #21
If you can bend a coat hanger to reach the set screw then there maybe a shot .Make a magnet out of the coat hanger and single strand of copper wire -once wrapped use heat shrink tube to cover the coil .A 9 volt battery should be fine .
dcdrechsel is offline   Reply With Quote
Old 01-21-2015, 07:45 PM   #22
Engine Surgeon
The problem you'll have with magnets is all the other heavy ferrous parts that are near this area. This includes the IMS drive, and its chain. The magnet will want to be attracted to these, before the missing fastener.
US Patent 8,992,089 &
US Patent 9,416,697
Old 01-21-2015, 08:42 PM   #23
On the slippery slope
JayG's Avatar
OK, then how does he find the set screw?
2004 996 Targa Tip
Instructor - San Diego region
Old 01-21-2015, 08:52 PM   #24
Nine8Six's Avatar
3M, double-sided tape lol
seriously. The stickiest you can find
Old 01-21-2015, 09:00 PM   #25
Nine8Six's Avatar
Just goog'ed some pretty neat Vacuum Pickup Tools. You'd possibly need something bigger than a hobby size tool tho. Just trowing some ideas for you, not that I've done that before
Feel ya from this side, wish you and your car the best of luck man :/
Old 01-21-2015, 09:43 PM   #26
Motorist & Coffee Drinker
78F350's Avatar
The set screw is in a place that a tool can not get to. I took a good look as I finished disassembling an engine today. Even with the head off and chain ramps removed, it didn't seem doable.
So, how about moving it to out of the IMS pit with a jet of air or fluid. You can push flexible tubing down there. If you can get the set screw to another spot, you have a much better chance of reaching it.
Old 01-21-2015, 10:03 PM   #27
Progress report
- I was able to slip a zip tie into the exact area where the set screw is. A coat hanger is either too large in diameter or too rigid (I think the former).
- I confirmed the screw is in that area by moving it around with a magnet outside the case and taking a video from inside. I tried this before but visibility was poor - vacuuming up most of the oil helped. Note in plain sight in the video is the IMS-crankshaft chain/sprocket. The screw is on the other side of it - I'm wiggling it around through the case with a magnet, and you can see the oil slosh around as a result.
- I tried moving the screw to the area that is visible by the camera, but it doesn't seem to go over there. Hypothesis is there isn't enough clearance beneath the IMS-crankshaft chain.
- Thus I have begun a project of trying to create enough clearance to move the screw to the area accessible by tools (seen in camera). First attempt was to tighten down the IMS-crankshaft tensioner and hope this would lift the IMS enough to scoot screw under. Tried once and failed.
- Another idea is to move the IMS up by sticking a pole into the hollow shaft and lifting up the pole. I've heard it's not to difficult to maneuver the IMS around like this. At present my LN engineering bearing is installed, including the center stud, making it impossible to fit a pole inside. I don't want to mess up the bearing by knocking out the support stud. Bad idea to knock the stud back into the IMS shaft and later reattach it to an already installed bearing? Other ideas of prying the IMS up?
Thanks to all.
gonzojive is offline   Reply With Quote
Old 01-22-2015, 12:28 AM   #28
Spinnaker's Avatar
Been following your progress with interest. I have always prided myself with having good problem solving skills and this one keeps me engaged. Not having in person first hand knowledge of the problem site makes it even more of a challenge.
First, I would like to know if you can rotate the chain and sprocket?
If that is possible, this is what I had in mind.
Get some of those small rare earth magnets and stick them on the chain in between the sprocket teeth. Rotate the chain and sprocket to where the set screw is and see if they can attract it and stick to the magnets. If they do, you can rotate the chain back and grab the set screw. Not much chance of losing the magnets, as they stick like crazy to anything ferrous. Just make sure to count how many magnets you use and account for them afterwards. The ones in the picture are from Harbor 'Fright'.
edit:
* Opps, I see that you have already thought of this upon reading earlier posts.*
Old 01-22-2015, 01:37 AM   #29
Originally Posted by gonzojive View Post
Progress report
Thinking more about it, it's probably not a great idea to pry the intermediate shaft up like that if it can be avoided. I don't want to damage the race that holds it in place on the other side.
Thinking even more about it, from the photo from flaps10, it seems like there should be enough clearance for the set screw to fit beneath the chain (looks to be 6mm or more - I can't tell for sure). The screw might be running up against the lip of that recess. I'll try to vacuum up even more oil to see if I can make the floor visible.
There are also holes in the sprocket big enough to fit the screw through.
And really, how about a hole in the case? Expand the bottom left IMS flange bolt to be M8 or M10 instead of M6?
Thanks to all.
Many clever ideas. Thanks again. Will surely get to try many of them in days, weeks, months ahead.
Old 01-22-2015, 04:04 AM   #30
Beginner
Jamesp's Avatar
I would not put any permanent magnet inside the engine. Electromagnet would be ok. A rare earth magnet will stick to anything ferrous and not come off. You will lose it in there and then have an even bigger problem. I'd get stronger magnets to use from the outside of the case to drag the screw up out of the hole. If you can pull the screw up high enough to touch the screw with the end of a coat hanger while both are in the magnetic field it will tend to stick to the coat hanger. As mentioned earlier the screw will be attracted to the IMS and chain as well as the magnets while both are in a magnetic field so you can expect to have to wiggle the magnet around a fair bit to tease out the screw. Away from ferrous material you should be able to move the screw around at will.
2003 S manual
Old 01-22-2015, 07:27 AM   #31
I hate to say it, you'll probably never get it out.
You know what I would do?
Curse. A lot
Next, I'd cry for a little while
Then I'd pull the engine down and take it apart.
I hope you can find a way to figure it out, but things arent looking too good for you.
Bigsmoothlee is offline   Reply With Quote
Old 01-22-2015, 01:08 PM   #32
Beginner
Jamesp's Avatar
[QUOTE=Bigsmoothlee;432776]I hate to say it, you'll probably never get it out.
QUOTE]
Don't give up yet, you might be on the one yard line! The fastener is in the "U" shaped channel in the lower right hand corner of this picture. Use a strong magnet from outside the block to drag the fastener up the ramp out of the channel. This would be dragging "into" and "up" for this picture. Once dragged up the ramp it's no longer in the channel and you might be able to see it with your endoscope. Pull it towards the center of the engine. If it drops from there you can grab it again through the aluminum with magnets from inside the oil reservoir area, in fact having magnets taped to the area you want the fastener to go might be a good move. Then drag it up to the large hole under the cylinders and into your hand. When you get this bolt out you need a vanity plate that says "986FISH".
One other thing, the gray oval on the casting near the hole for the IMS seal is where the IMS drive chain kissed the block after a complete IMSB failure with a broken bolt. After quite a bit of bolt turning in my garage the engine is in my daily driver and runs like a top. Never give up!
2003 S manual
Old 01-22-2015, 01:35 PM   #33
woodsman's Avatar
If you can wiggle it with a small magnet from outside the case then you can move it with authority with a big enough one. Oh and soak up that oil- it causes drag...
Old 01-22-2015, 01:35 PM   #34
Just want you to know that we've all been there and done something like this at one time or another. You have an army of guys trying to help figure this out and hope that you are successful.
I'm glad that there was no internet the time that I cracked the head and broke a chunk out of the block when I forgot to remove a somewhat hidden head bolt and went ahead and gave it a little "help". Yeah, it happens to all of us.
Old 01-22-2015, 02:52 PM   #35
Engine Surgeon
Access though the IMS tensioner hole may yield some results, too.
You can tear the engine down "on the half shell" and leave all of bank 1 together, only removing the exhaust cam sprocket bolts, locking the bank 1 cams in place. This allows complete disassembly of bank 2, and access to the IMS region to fetch this fastener, without total engine disassembly.
We do this all the time in development, changing components for back to back tests.
US Patent 9,416,697
Old 01-22-2015, 11:48 PM   #36
Spinnaker's Avatar
If the possibility of using a magnet from the outside of the case sounds like something you might try, get one of these from Harbor Fright'. It is the strongest magnet I have come across that is easily obtained.
Retrieving Magnet, 250 Lb. Pull
Got one to retrieve tools that get dropped off the dock when working on the boat. If you have ever been around boats, then you know that its only a matter of time until something visits Davy Jones.
Here's a pic of it holding a 5/16" set screw through a 1" thick bar of aluminum.
If you lived closer, I'd let you borrow mine. They are currently on sale for $19.99
Old 01-23-2015, 08:20 AM   #37
Engine Surgeon
If you get that magnet near the engine you'll magnetize the IMSB. Doing this guarantees that any ferrous debris inside the engine will be sucked into the races of the bearing. This causes certain death.
I have seen this before, and we have to stay join the asses of distributors NOT to ship IMSBs with magnetic drain plugs.
Also, if you magnetize the lifters, they'll suck up debris and the engine will sound like a small diesel.
Magnets that are this powerful have mo place around an engine.
There;s a time when avoiding the issue creates other issues. I'd suck it up and take it apart.
US Patent 9,416,697
Old 01-23-2015, 08:45 AM   #38
Maybe you can buy a flexible camera probe and see where it is.
Old 01-23-2015, 09:18 AM   #39
Originally Posted by jake raby View Post
i'd suck it up and take it apart.
+1..........
Old 01-23-2015, 09:19 AM   #40
It is going to require a very small camera head to get in there, which will be expensive.
