Old 11-02-2014, 11:04 AM   #6
DennisAN's Avatar
Originally Posted by Jamesp View Post
I made my own puller and installation tools. As I had the engine out of the car, it was easy access so the tools worked. I did booger a bearing shield installing the new bearing and had to buy another new bearing. If I were working in a confined space, I'd buy the tools, the job is specialized enough to warrant that.
Your 2003 should have a single row IMSB. IIRC Raby's biggest difficulty was designing a puller to extract the dual row IMSB, which requires much more force to pull it out.
NOTE: the tool kit also includes the crank and cam locks, and the broken stud extractor tool. This hasn't been mentioned previously. The only suggestion I'd make is that LN could throw in the two bolts that are needed to put the cam locks into place. For the record you need bolts size M8 x 1.25 x 20.
Base 2000 986, beater 1996 Miata, 2011 Suzuki SX4 AWD
Feline mechanics Condoleezza and Dukie
DennisAN is offline   Reply With Quote
