08-16-2014, 02:40 PM
Artist, 986S tinkerer
Uh, maybe it IS the O2 sensor...
Thought I'd swap over my O2 sensors to check if there was a problem with one. Pulled off first post cat. Hmm, think I found the problem. 😏
08-16-2014, 09:18 PM
wow looks like the shield was burned/melted right off.
What symptoms were you seeing? O2 codes? Rough running?
I think I need to pull mine and check that as well.
08-17-2014, 05:30 AM
Actually, it ran just fine. Had a CEL and the code was a p0430, which signals a bad cat ( or maybe a sensor that is toast). Also the Durametric readings for pre and post cat were both in roller coaster mode.
08-17-2014, 09:39 AM
How many miles on this O2 sensor?
Jäger
300K Mile Club
08-17-2014, 09:45 AM
Don't know really. The car has 85k miles on it but I've only had it for a year or so. The O2 on bank 1 is clean.
08-17-2014, 01:57 PM
Congrat's! Its always nice to find the exact cause of the problem on the first try!
I usually employ the "replaced-345-parts-and-its-still-not-fixed" approach.
08-17-2014, 05:23 PM
Too funny. Sounds like someone I know!
08-18-2014, 07:07 AM
Yep, sometimes they do get fouled. Now for the next big question: Why did that bank get so fouled with oil??
08-18-2014, 09:39 AM
Actually, it is not really fouled with oil. The outer shell is broken/corroded/missing and is coated with carbon deposits. The inner sensor is faking off as well. Could be the result of the massive air leak due to a broken oil filler tube and the resulting backfiring and other small explosions that I heard. All fixed now. We'll see...
08-18-2014, 09:44 AM
Those heavy carbon deposits look like excess burned oil in the exhaust to me... but I could be wrong.
08-18-2014, 09:51 AM
Is that a oem or Bosche O2 ?
08-18-2014, 09:53 AM
Not to mention a guaranteed performance improvement for your money spent!
08-20-2014, 09:45 AM
Yes, you are probably right. I have replaced the sensor but the readings still indicate a cat problem. Marbe I'll try a smoke test on the exhaust to check for leaks. I changed the AOS in the spring and the MAF is fairly new as well. Hopefully it's not really the cat. Major $ !
08-20-2014, 10:10 AM
If you end up needing a cat or cats I happen to know a guy that has both cats from my donor engine
2001 Boxster S 6speed- weekend warrior
2015 Explorer Sport- New DD
2011 Taurus SHO- Sold
2010 CBR1000RR- Sold
08-20-2014, 03:07 PM
Hopefully I won't need them ( it ). All 4 cats ?
08-20-2014, 04:40 PM
Maybe pull and compare spark plugs on both banks. If one side is heavily carboned, you know there is oil in the combustion chamber.
09-20-2014, 07:01 PM
so I bought a used cat on eBay for 120 bucks. Install no sweat. Running for a week and no codes yet. Probably too early to tell (touch wood) but my SAI codes haven't come back either. Wouldn't that be lovely!
09-21-2014, 08:16 PM
Congrats
