Old 08-16-2014, 06:41 PM   #21
Reebuck1
Well said !!
Reebuck1 is offline   Reply With Quote
Old 08-17-2014, 07:14 AM   #22
fasted911
fasted911's Avatar
Send a message via AIM to fasted911
o.k took your advice on holding down the bearing carrier.got piston rings on pistons 1,2,3. here is a pic
now im getting baskets & o-rings (and so)for next step. other crank case half 4,5,6.
any suggestions,heads up,warnings,etc.how am I doing
fasted911 is offline   Reply With Quote
Old 08-17-2014, 07:20 AM   #23
Suggest you watch this.1 of many.
https://www.youtube.com/watch?v=ksU3_zVqlfs
https://www.youtube.com/watch?v=-8PI2cCmvqU&list=UUrDWnILOwrDkDn5gFgBNbtA
Old 08-17-2014, 11:00 AM   #24
and this:
Project NUTROD- Porsche Boxster M96 Engine Removal
Old 08-21-2014, 03:10 PM   #25
fasted911
fasted911's Avatar
book reads to change crankcase bolts when you rebuild engine.is this necessary.?the m6 bolts for crank case are steel.(not aluminum)anr torque is
20 NM(15tflbs) .what do you know?
Old 08-21-2014, 03:26 PM   #26
Did you read this?
Engine Assembly
The take home is -no short cuts or economies are allowed.That is why this is such an expensive process.
There is probably a place to buy these bolts for a fraction of the usual price but I have not read any post confirm that nor if they were successful. I really resent paying through the nose for generic parts that Porsche just re-labels but...............
Old 08-21-2014, 03:47 PM   #27
fasted911
fasted911's Avatar
Red face
i did= its good,but no specific details. ohhh. m6x30 are 13Nm.i was incorrect the first time.
Old 08-21-2014, 04:01 PM   #28
13Nm ? that is less than 10 ft pounds.
Old 08-21-2014, 04:04 PM   #29
And this:
http://rennlist.com/forums/996-forum/672370-engine-rebuild-part-3-the-finale-7.html
Old 08-28-2014, 02:39 PM   #30
fasted911
fasted911's Avatar
All right ready to unite crankcase half. what type of silicon should I use. what about heads,i know they use head gaskets. can someone help,water pump and oil pump use gaskets as well. any other silicon anywhere else????
Old 08-28-2014, 02:45 PM   #31
Suggest you search for "curil T" , "3+bond" , Loctite 574.
This may help:
Where to apply sealant - Pelican Parts Technical BBS
and
Engine rebuild sealants - Pelican Parts Technical BBS
Yes, it is complicated,yes it's an M96 !
Old 08-28-2014, 02:51 PM   #32
BYprodriver's Avatar
Drei-bond 1209 sealer available at several Porsche dealers these days. Use it for case halves & cam covers. If you have enough left use it for the sump plate cover also. Erling or oem for head gaskets. No sealer anywhere else.
Old 09-04-2014, 05:41 PM   #34
fasted911
fasted911's Avatar
On my book i came across this page notice #1 bolt(cannot find it.) it is a m9x150mm i found bolts #3 & #5 from this diagram.so i when to local dealer and ordered #1.
Question #1-right when i drop bearing carrier in 1,2,3 crankcase half and 2 gaskets are there any more o-ring or gaskets?
question #2 than add 4,5,6 crankcase half than the #1 bolt in center top of picture than bolt #3 & 5????
alright.here is this pic of halves and hardware
Old 09-06-2014, 07:27 AM   #35
Yes just a couple O-ring type gaskets for crankcase halves. Did you get a full rebuild gasket set? There are many O-rings required, Those long bolts have O-rings, before you install the heads, install those 3 long bolts finger tight. After you torque the heads, then torque the 3 long bolts.
Old 09-06-2014, 12:08 PM   #36
Engine Surgeon
You did install the two large cross flow cooling system gaskets between the case halves?
US Patent 8,992,089 &
US Patent 9,416,697
Old 09-12-2014, 05:24 PM   #37
fasted911
fasted911's Avatar
gasket kit
I got that. has anyone used Victor-Reinz engine rebuild kit. I'm at the three bolts that you install after crankcase halves come together two of the bolts have black o-rings now.the Victor-Reinz kit doesn't have black ones that size.what do you say?
Old 09-12-2014, 05:41 PM   #38
That's why I use the Porsche gasket kits, they supply oem bolts also. I also bought a Metric O-ring assortment.
Old 09-18-2014, 11:11 AM   #39
fasted911
fasted911's Avatar
yes.but my dealer told me they had no kits.individual only.but that's cool.I've gone though it and i only need a few that Victor-Reinz doesn't have.number 6 piston was a challenge.wow what a thrill.5 and 4 next
Old 09-20-2014, 11:11 AM   #40
fasted911
fasted911's Avatar
Red face cam timeing tensioner
Does anyone know if the cam timeing tensioners out of your heads can be rebuild.are theys shops out there.I notice after I took them out one of the ball bearings was missing here is a pic.look at one on the right.
