08-10-2014, 12:49 PM
#2
There's a disclaimer in the ad that says they are not compatible with German cars.
"The led kit is not suitable for the Germany car, for example: BMW, AUDI, Volkswagen, Mercedes-Benz ect."
If they were compatible, I agree they would be great. There must be another manufacturer offering ones that are compatible.
08-10-2014, 02:40 PM
#3
THere were several like it listed on eBay, many listed Porsche, BMW and Mercedes as compatible . I worry about heat and current draw
08-11-2014, 05:33 AM
#4
I bought 25w H7's. I would think 60w would generate too much heat.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
08-11-2014, 07:12 AM
#5
MOre info
I have been reading up on this, they are actually about 27 watts per side. They use what looks like a HID Ballast, but in actuality it is called a driver. More checking reveals it is simply a constant voltage and current regulator that will supply a constant +3V to the LED unit that has a tiny fan on the rear to assist the aluminum heatsink built into the lamp assembly. My concern since the total Max current draw is only 2 amps per side is will the rear cooling fan/heatsink fit inside our headlight assembly?
The light output looks to be roughly the equivalent of a 35W HID conversion. THe price is appealing and seems to average from 60 USD to 85USD.
Perhaps someone else will weigh in on this with some actual hands on experience.
PS this looks to be a newer form of Cree called a "COB Cree array" and is much more efficient than what we have been seeing in the past.
10-19-2014, 07:09 AM
#6
I am also very interested to see if anyone installed this type of bulb. I plan on doing the DRL fog light hack with LEDs installed, and thought this would be a great upgrade until the rest of the car is up to snuff.
10-19-2014, 07:39 AM
#7
Very interesting.
Guvs.
10-19-2014, 11:36 AM
#8
Dwight - those kits made in Asia with all the fancy/marketing fan-cooling thing are to be avoided atm. I've read various reports here on the local retrofit forum that the fans prematurely fails (similar IMS bearing design I'm guessing). Also read reports of melting cabling/terminals (fire hazard, dunno). Its just a plastic dumb fan.... last a few weeks under constant high temp and vibration conditions. They DO get hot... the high lumens aftermarket does anyway (hence the fan/over-sized heat shield design idea)
... and they are NOT cheap to start with lol
Perfect for the rusty Ford Ranger 1994 but perhaps not yet ideal for the Porsche car club. Careful with those thing.... is the msg I got from the pros here
CREE is real and I advise anyone to stick to the official product only ( Cree, Inc. | LED lighting, LEDs, power converters, RF amplifiers). And I don't think they design car lighting systems yet (could be wrong of course)
10-19-2014, 11:41 AM
#9
Cheap LED rocks.... safe, efficient, and 99% of the time they will fit  For the fogs anyway... Max 20~25 watts and you should be fine
10-19-2014, 12:33 PM
#10
Fogs
Fogs are what I was thinking about, I have the Main Headlight problem almost solved. I would love to have one of these LED replacement H Bulbs to put on my bench and measure current draw on start up and sustained , also heat startup and sustained...then measure the Lumen output with my instruments after running for a few days constant on. Did I mention I worked almost my entire life in the Photo Industry with my speciality being Dichroic Lamphouses that cost as much as a new Boxster. But I digress those days are long gone, Photo is dead and has gone the way of the Buggy Whip. Now I am a lowly Biomed person
10-19-2014, 01:19 PM
#11
I believe that the claim by sellers that their lights will not work in German cars applies to the newer cars that will detect faults with any electronic draw besides the intended bulb.
After going through a lot of different bulbs for my fog lights I came across these on eBay. IMHO, they look great. No heat issues.
2 Pcs H7 SMD5050 12 LED Car Front Fog Light Bulb White CREE Q5 Lamp 12V 30V S0BZ | eBay
1995 Porsche C4 Cab
10-20-2014, 05:55 AM
#13
Originally Posted by Chuck W.
I just bought a set of these; when they get here is a few weeks I will report back  I am wanting to enable the Fog light DRL hack and once I get these I will do it.
Steve
10-20-2014, 07:52 AM
#14
It took them eight days to get to me from China. With any luck you'll set them in the same time frame.
1995 Porsche C4 Cab
10-27-2014, 03:44 AM
#15
02Brutus986
From what I have read about Cree is, that they are a good Co. With quality products. Last week I tried to change out my break & tail lights with LED bulbs from Pilot Co. And could not get them to come on. Anybody out here know why the LED bulbs would not come on? Pilot claimed that you will not get any check eng light, which was true, but could not get their lights on either.
10-27-2014, 04:07 AM
#16
Hope this link works.
http://www.boxa.net/forum/index.php?showtopic=62675
It tells you why the LED rear light bulbs don’t work, and a fix for it, on our UK models anyway, should be the same for you over the pond.
Guvs.
10-27-2014, 04:15 AM
#17
The link goes nowhere ??
10-27-2014, 04:40 AM
#18
550 Anniversary
Link works fine for me. You might need to be a registered user and logged in.
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
10-27-2014, 04:57 AM
#19
I have tried to register on that board several times with no luck. I even emailed the admin about never getting the verification link with no luck or return email.....Im glad our board here is run much more professionally.
Dwight
10-28-2014, 10:09 AM
#20
02Brutus986
Same here. No luck getting on that page to read it. I will keep working on it because I want to find out how to get my lights to run LED's
