Old 07-30-2014, 06:14 PM   #5
Beginner
Jamesp's Avatar
Originally Posted by fasted911 View Post
thanks for the advice.did you drill holes at top and than 180' (below)right in the middle of head timeing chains gear.?
That's me. I have some youtube posts out there explaining why this should fix the problem and how to do it. Cheap and easy. Use a fully sealed IMS bearing with grease and with a full Viton seal. A good Nachi bearing fitting this bill can be had for 10 to 35 bucks. Get the $10 bearing it's the same one as the $35 one. I also saw a sealed ceramic that looked promising, but make sure you get the right type of ceramic. If, and that's a big if, the grease can be kept in the steel bearing it should be fine. That's why I went for high temp grease in a high temp full seal bearing (Viton) and relieved the pressure in the IMS. :dance:
2003 S manual
