Old 04-29-2014, 06:42 AM   #1
seningen's Avatar
OBDII Oil Temp?
Does anyone know if the Boxster supports OBD-II oil temperature?
I've got a ELM327 WIFI connection to my IPhone.
I'll need the PID information if I want to setup a gauge?
example:
oil temp PID for the Toyota 86.
PID 2101
Min -40
Max 215
Scale x1
Unit Type C
Equation AC-40
OBD Header 7E0
I've already plumbed for physically duplicate oil temp and oil pressure gauges
but since I have the OBD-II also working, was thinking that might
be an option as well.
thanks,
Mike
mike@lonestarrpm.com
Old 04-29-2014, 10:33 AM   #2
I've assumed that your do this for your '00 Boxster ( which is DME 7.2). The oil temperature is checked by the DME because codes P0197 and P0198 are thrown for below/above limits (oil temp is used for cam adjustments). You may be able to see the actual value from your device -- I can check it with my Durametric on my '07.
Regards,
paul...
paulv is offline   Reply With Quote
Old 04-29-2014, 11:01 AM   #3
seningen's Avatar
Regards,
paul...
Yes -- my 00 S Boxster. I'm coming up to speed on OBD-II
I believe the codes are not in the first 32 -- so are extended -- therefore
I need to know the PID and then the characteristics.
I've also found a thread where they think you can display it on the HVAC controls,
but in the long run I'd like to maybe display a good bit of info on a IPAD -- but I'll start
with my phone.
thanks,
Mike
Old 04-29-2014, 11:53 AM   #4
jb92563's Avatar
Do a find on the below page for "oil" (engine oil temp pid = 5c)
More PIDS than you can shake a stick at
OBD-II PIDs - Wikipedia, the free encyclopedia
I have one of those ELM 328 OBDII readers (Bluetooth) as well that I wanted to use for extra guages as well.
What software are you using with yours on your phone?
