Old 04-19-2014, 02:49 AM   #1
brake pad recommendation ?
2002 S that will need rear brake pads soon so I think I'll do all four corners to get a good baseline as the car is new to me. On past air cooled Porsche's I have used Porterfield brake pads with great results any of you running these on your Boxsters ? Specifically R4S compound. Just looking for a little more bite for street/AX while maintaining rotor friendly with minimal dust........not asking much . I'd like to hear what others are using.
Old 04-19-2014, 05:53 AM   #2
Nine8Six's Avatar
ceramic onto cheap/but great gray cast rotors here. Street use, no warm up time, instant bites
Old 04-19-2014, 03:12 PM   #3
I also use EBC Redstuff (on the 996). Its a great street/track pad with excellent initial bite and won't easily fade. Also, since its a ceramic pad you'll see a 75% reduction in brake dust compared to OEM pads.
Old 04-19-2014, 08:59 PM   #4
Try the Mintex pads. They are the cheapest OEM pads. About $60 for the fronts. They have a better coefficient of friction than the very expensive Brembos which gives the Mintex a very good initial bite, on thenstreetnor track. I have used themon the track and they are great. No fade, but you will go through about half the pad on a DE event. They are very easy on the rotors.
On the street they are fine, very little dust, no noise.
To me it's a no brainier. Unless you are really racing, stock pads work fine.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 04-20-2014, 02:06 AM   #5
For you guys running the EBC Red Stuff pads I was reading some online feedback and there were some complaints about noise and the lack of a mounting spot for the OEM wear sensor. Have you had these issues ? I will look into the Mintex. Thanks guys
Old 04-20-2014, 02:29 AM   #6
I run the red stuff. No issues with sensor mounting. I had a little squeak the first month or so in stop and go traffic and light braking but now it is gone. I ended up getting them off ebay last fall for under $150 for fronts and backs.
mump is offline   Reply With Quote
Old 04-20-2014, 03:38 AM   #7
Cheapest I have found so far for the EBC red is a place called " Place for brakes ". They want $107.73 front and $98.19 rear with free shipping. I'll continue to look around I don't have to pull the trigger just yet and I need to determine if I can turn the existing rotors or replace.
Old 04-20-2014, 06:15 AM   #8
edc
550 Anniversary
edc's Avatar
I'm on Ferodo DS2500 for front only. No wear slot so sensor shorted and tied out the way.
Old 04-20-2014, 07:29 AM   #9
They have the hole for the brake sensor. A bit of squeal is normal until the pad is bedded in around 100 miles. After that, perfectly quiet.
Old 04-20-2014, 02:31 PM   #10
jsceash's Avatar
I've had EBC red and they run fairly well. I have not had a problem with the EBC at all with the sensor holes they fit and align as well as the OE pads do and with less dust in the red pads.
