Old 04-10-2014, 10:44 AM   #1
Beginner
Jamesp's Avatar
Hard Starting When Hot
I have had one episode of a hard start while hot. I drove to the store and back, about 5 miles. I turned off the car in the driveway and then decided to put it in the garage. I attempted to start it about 10 seconds after turning it off and it would roll and hit, but not catch and run. It was right on the edge of starting, so on the third try I just kept the key turned until it started, which took maybe 5 seconds. It ran fine after it started. Any ideas? Normally it starts instantly - 2003 S 6 speed -
2003 S manual
Old 04-10-2014, 11:03 AM   #2
Check your fuel pressure.
Old 04-10-2014, 11:30 AM   #3
Take a look here.
Success! Finally fixed the hard start while hot and fueling issues.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 04-10-2014, 05:51 PM   #4
http://986forum.com/forums/general-discussions/51323-random-starting-issues-cel.html
I had some issues with starting as well a couple weeks ago. Fixed it with the regeneration valve that I mentioned in my post that I provided the link for.
I bought it at the dealer for around 130 dollars but it was a massive pain to replace. Hard to get any good angles to get it out so I ended up taking half of the upper engine parts out to get to it under the intake manifold. Then you have to get to the bottom connection from under the car with the liner removed. Def recommend taking off your trunk lid to sit in it while you work. Made it a lot easier.
BrandonJames89 is offline   Reply With Quote
Old 04-10-2014, 06:07 PM   #5
seningen's Avatar
Or buy the entire path and bypass the valve completely.
I happened to have an extra laying around the shop -- made that fix easy :-)
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
Old 04-10-2014, 06:17 PM   #6
Mike
That would have been a much better idea. The old valve would not come out of the hose I needed to keep so I had to cut it. How did you remove the old one with the bracket that connects under the manifold holding it?
