Old 04-10-2014, 06:07 PM   #5
seningen
seningen's Avatar
Originally Posted by BrandonJames89 View Post
http://986forum.com/forums/general-discussions/51323-random-starting-issues-cel.html
I had some issues with starting as well a couple weeks ago. Fixed it with the regeneration valve that I mentioned in my post that I provided the link for.
I bought it at the dealer for around 130 dollars but it was a massive pain to replace. Hard to get any good angles to get it out so I ended up taking half of the upper engine parts out to get to it under the intake manifold. Then you have to get to the bottom connection from under the car with the liner removed. Def recommend taking off your trunk lid to sit in it while you work. Made it a lot easier.
Or buy the entire path and bypass the valve completely.
I happened to have an extra laying around the shop -- made that fix easy :-)
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
