Old 04-03-2014, 01:32 PM   #6
The Radium King's Avatar
ditto weight - lw seats (rottec if you don't need fia approval) a/c delete, roof transmission and motor delete (roof works just fine in manual mode). perhaps stereo delete. if no emissions testing then secondary air and carbon canister (a row flash will get rid of any cels that may arise). oz wheels from tire rack are the best $/lb deal out there.
for more power, smallest udp is 4" - make sure you don't have the 5" that is also available. you've done exhaust. 987 air box (and trim the air filter hanger to improve airflow - good for a few more hp according to planet 9). pedro sells the intake plenum/larger throttle body/dme flash as listed (get a hard limiter if possible). after that, get a wideband afr gauge and trim your open loop afr a little closer to stoichiometric. see if you can bolt an intake manifold for a 3.2 onto your car - might give a bit more top end oomph.
all should look relatively stock and keep you in your class.
