Old 03-18-2014, 05:56 PM   #1
2000 986 & 1972 914
martinef1963's Avatar
Question Location: 00 Boxster Purge Valve
Can someone point me in the right direction: LH / RH side of engine, top / bottom of engine compartment / or other location were I can find this part that I want to change?
I purchased a regeneration valve and purge valve and just can't find the location of the purge valve.
Both these numbers are on the box the purge valve came in:
PN: 996-605-201-01/244
PN: 7.22098.04.0
Any help would be appreciated.
thanks,
Fern
martinef1963 is offline   Reply With Quote
Old 03-19-2014, 06:50 AM   #2
Not exactly sure about the valves, but the carbon canister is located in the passenger side fender behind the wheel. You have to remove the wheel and the fender liner to get to them.
This link has a photo of the canister location: http://www.renntech.org/forums/topic/40799-evaporative-canister-question/
And this link shows the whole EVAP system: http://forums.pelicanparts.com/boxster-cayman-forum/669017-hot-start-problem-code-p0446-2.html
Old 03-23-2014, 12:00 PM   #3
Brad Roberts's Avatar
Did you find it? It's located behind the right front wheel, behind the fender liner.
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
Old 03-24-2014, 07:35 AM   #4
If those are solenoid valves, you can test the old ones by applying 12 volts to the terminals. Watch the polarity.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
