Old 03-14-2014, 06:51 AM   #1
Artist, 986S tinkerer
NewArt's Avatar
Camshaft tool P253
Okay, next in line is the camshaft locking tool P253
Is this $235 tool necessary to set the cam timing?
Old 03-14-2014, 11:45 AM   #2
Pretty much, unless you plan to fabricate your own.
Old 03-14-2014, 02:29 PM   #3
NewArt's Avatar
Which doesn't look difficult. I easily fabricated the camshaft hold-down tool. Here I see a piece of flat bar with a disk which mates with the slot in the camshaft to lock it parallel to the seam. Is it exactly parallel? If so, I could construct this in an hour or so. Might not be quite as pretty. Thanks for your input! :-)
BTW is there a functional difference between this tool and the 9612 tool with the lovely red knobs?
Old 03-14-2014, 02:39 PM   #4
The 9612 tool is designed for when you need to hold the cams while removing one of the cam drive sprockets that the chain goes around.
Old 03-14-2014, 06:54 PM   #5
I have one I will sell you for $130, never used or the complete $600 Baum tool set for $350 brand new or both for $450
davedeck is offline   Reply With Quote
Old 03-15-2014, 06:08 PM   #6
NewArt's Avatar
Davedeck, I'm in Montreal. I may be interested in this (it's the P253?). Depends on the shipping cost etc.
Old 03-15-2014, 06:42 PM   #7
Yes it is the Pelican P253. Send me a PM with your address and I'll check shipping. It's on EBay if you want to see a pic of it.
Old 03-16-2014, 06:44 AM   #8
NewArt's Avatar
PM sent. Couldn't locate the e-bay listing. -J
