Old 03-14-2014, 02:39 PM   #4
JFP in PA
Which doesn't look difficult. I easily fabricated the camshaft hold-down tool. Here I see a piece of flat bar with a disk which mates with the slot in the camshaft to lock it parallel to the seam. Is it exactly parallel? If so, I could construct this in an hour or so. Might not be quite as pretty. Thanks for your input! :-)
BTW is there a functional difference between this tool and the 9612 tool with the lovely red knobs?
The 9612 tool is designed for when you need to hold the cams while removing one of the cam drive sprockets that the chain goes around.
