Old 02-19-2014, 11:15 AM   #1
DIY extremist
black_box's Avatar
Weak points of M96/97 Engines other than the IMSB
(I know this is 987 question, not 986, but you guys seem to know a lot about engines)
Ok, so I am 99% certain to be taking the plunge and investing in a boosted Cayman (deposit is down).
The motor was shipped to LN for machining and sleeving, 100mm pistons are forged JE 10:1, new crank with stock stroke so displacement is 3.7L, billet rods from LN, ARP bolts, all new bearings, IMS retrofit done, upgraded oil pump. TPC stage 2 intercooled turbo, Dynoed at 460 WHP/ 420 WTQ on conservative boost and tune, stock rev limiter.
Motor has 5k and two oil changes so far w/ used oil analysis looking good. Not tracked by current owner.
Planning to do AX/Track with this beast on dedicated sticky tires, keeping my Boxster S for when I take the girlfriend (Probably still going to sell before end of summer)
So the big question is:
What are the failure points now? Do you think that this build addressed the weaknesses of this motor sufficiently?
I know that high-g oiling is an issue on M97s, so I may look into an Accusump or similar if I run anything stickier than Direzza ZIIs or RE-11s.
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
black_box is offline   Reply With Quote
