01-14-2014, 04:02 AM
#1
Beginner
[QUOTE=Jake Raby;380855]That engine has compression all over the place.. I can hear it based on the load on the starter.
I had the engine completely torn down for an IMS shaft replacement.
I locked the engine at TDC and timed both banks using a factory built timing tool and the instructions from the 987 manual
It has the original lifters in it.
Both banks were timed the same way, meaning engine locked at TDC and timing tool used.
The picture below shows bank 1-3 timing
2003 S manual
01-14-2014, 06:48 AM
#2
[QUOTE=Jamesp;380902]
Still worth a quick double check that your still in time.
pull the oil scavenge covers and make sure the cam sprockets didn't slip.
left and right bank do get timed 180 out of phase. Been a while since
I personally checked but the cam holder gets rotated such that
when timed both camshaft sides are slightly on the outside of the case.
Double check that as it's been a couple years since I did it myself.
mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
01-13-2014, 06:53 PM
#3
Registered Boxster abuser
meaning that the cranking pulses are not at a even pattern when you crank it.
01-13-2014, 07:37 PM
#4
Engine Surgeon
Absolutely. That tells the story when you have a trained ear.
US Patent 8,992,089 &
US Patent 9,416,697
01-13-2014, 07:52 PM
#5
Check Cam timing and do a compression and/or leak down test.
Sounds uneven.
m
01-13-2014, 08:11 PM
#6
Engine Surgeon
Lifters may be sticking to create this
But I have another idea after he replies to my previous questions.
US Patent 9,416,697
01-13-2014, 08:54 PM
#7
Sounds like both banks are timed the same instead of being 180 degrees opposite.
01-14-2014, 03:52 PM
#8
Beginner
I think you are right. So do I expect bent valves at this point? Seems like I would not because the valves are opening and closing exactly opposite on one bank.
2003 S manual
01-14-2014, 04:19 PM
#9
Beginner
So, off the top of my head here is a fix for this screw up. please review and comment:
Step:
1) Lock the engine at TDC with the 4-6 side cams in the position where they can be locked
2) Remove cam chain tensioner for the 4-6 side
3) Pull the oil scavenge pump in the engine compartment
4) Remove the cam sprocket
5) lock the cams with the cam locking tool
6) Unlock the engine and carefully rotate the crankshaft clockwise 360 while feeding the cam chain over the inlet sprocket - likely get a piece of plastic to put between the chain and inlet sprocket teeth while rotating
7) With 4-6 cams locked into position, re-install exhaust sprocket
8) remove cam locks and torque sprocket
8) tighten up tensioner
9) replace scavenge oil pump
10) replace cam plugs
So - what's missing? How can it be improved?
2003 S manual
01-14-2014, 04:25 PM
#10
Beginner
I'll take the easy missing piece - unlock the engine!
2003 S manual
01-14-2014, 12:35 PM
#11
Not that you did it wrong but if I remember correctly the timing tool for one head is not used for the other when the motor is at TDC for number one.
Am I correct?
01-14-2014, 04:31 PM
#12
Beginner
Am I correct?
The timing procedure seems to go like this - Lock the engine at TDC and set the valve timing using the timing tool. Head 4-6 is shown first in the repair manual, but I dont see a difference in which head gets timed first as there is only one TDC sr=etting on the crank. Now for the part I missed - Roll the crank 360 degrees (that's half a rev of the cams) and see the other side. Now the cams are set 180 degrees out from one another. I have one set of cams out 180 degrees. BYprodriver hit it on the head.
2003 S manual
01-14-2014, 04:42 PM
#13
Go get a boroscope and insert it into the spark plug hole
You'll need the more expensive, smaller one to fit into the spark plug hole.
You can see if there is valve strikes in the pistons
It will typically show up as a shiny half moon arc
If it's there, you probably have bent valves.
You really don't want to risk starting with bent valves
They could stick and break off
Which obviously would not be good.
Mike
01-14-2014, 04:59 PM
#14
Beginner
The question I have is do you bend the valves 180 out of time? Surely this has been done before.
2003 S manual
01-14-2014, 05:26 PM
#15
NO, I'm thinking you just forgot to spin the engine 360 degrees after setting cam timing on 1-3 cyl bank, & prior to setting 4-6cyl bank. If that's what happened the valve to piston clearance is as designed but DME is not programmed to send spark & fuel at the appropriate time for 4-6cyl combustion stroke.
01-15-2014, 08:51 AM
#16
I really wonder if the motor is a interference motor when the instructions tell you to just rotate the motor 360 with no regard to cam position?
01-15-2014, 08:55 AM
#17
Engine Surgeon
Trust that it is a heavy interference engine.
Not rotating the engine when setting cam timing only phases both banks of cylinders simultaneously.
This creates two 3 cylinder engines and the engine would run if it had batch fire injection and a wasted spark ignition system.
That sound on the starter tells the entire story when this occurs.
US Patent 9,416,697
01-15-2014, 09:13 AM
#18
It doesn't take much -- a properly set engine whose IMS Sprocket slips and rotates slightly
will take out all the valves -- so this tells you that the clearance is very tight.
(it's one of Jake's 99 millions ways these engines fail :-)
Mike
01-14-2014, 04:17 PM
#19
Id just make sure none of the pistons on that side of the motor is at TDC when you rotate the cams to where they are suppose to be, that way they will not touch the top of the pistons when you do rotate the cams.
Just rotate the crank about 30 degrees from TDC, put the cam where its suppose to be then rotate back to TDC and put the chain on.
then do a compression test.
Easier said than done.
01-14-2014, 04:38 PM
#20
its sucks how we sometimes just miss one simple step and it totally fubars everything.
