Old 01-14-2014, 04:42 PM   #13
seningen
seningen's Avatar
Originally Posted by Jamesp View Post
The timing procedure seems to go like this - Lock the engine at TDC and set the valve timing using the timing tool. Head 4-6 is shown first in the repair manual, but I dont see a difference in which head gets timed first as there is only one TDC sr=etting on the crank. Now for the part I missed - Roll the crank 360 degrees (that's half a rev of the cams) and see the other side. Now the cams are set 180 degrees out from one another. I have one set of cams out 180 degrees. BYprodriver hit it on the head.
Go get a boroscope and insert it into the spark plug hole
You'll need the more expensive, smaller one to fit into the spark plug hole.
You can see if there is valve strikes in the pistons
It will typically show up as a shiny half moon arc
If it's there, you probably have bent valves.
You really don't want to risk starting with bent valves
They could stick and break off
Which obviously would not be good.
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
