Old 01-09-2014, 12:31 PM   #1
boxster6354's Avatar
Starter Grind
Hi All
Seeking advice for an issue that just started:
When I go to start the car I get a grinding noise for a brief second after it starts, sounds similar to if you turned the ignition on a car that is running.
Not holding the key in start position longer than normal, car starts find (for now) but just seems the ignition stays engaged for a couple sec's after start.
2000 base @ 65k mileage.
Thanks for any input or suggestions.
boxster6354 is offline   Reply With Quote
