				Starter Grind
			Hi All
 Seeking advice for an issue that just started:
 When I go to start the car I get a grinding noise for a brief second after it starts, sounds similar to if you turned the ignition on a car that is running.
 Not holding the key in start position longer than normal, car starts find (for now) but just seems the ignition stays engaged for a couple sec's after start.
 2000 base @ 65k mileage.
 Thanks for any input or suggestions.
