Old 12-11-2013, 10:49 AM   #1
scottvd's Avatar
Horn only works with no key
I'm looking to purchase a 2004 S, the PPI revealed this problem:
"Horn only works with key removed, possible bad ground in column."
I searched the forums and found this post which sounds very similar. Checking in to see if anyone else has experience with this- thanks in advance.
Scott
scottvd is offline   Reply With Quote
Old 01-02-2014, 12:13 PM   #2
scottvd's Avatar
For archiving sake:
UPDATE: diagnosis revealed it was indeed the clockspring that needed to be replaced to solve the horn problem.
Old 01-05-2014, 11:48 AM   #3
I had the exact problem with my 2000S. I replaced the clockspring and the problem went away. If I hadn't been provided the part with the car, I probably would have tried to repair the original part. I read a couple threads on a 996 forum that said a short occurs in the ground wire about half an inch from the terminal.
MFozz is offline   Reply With Quote
