Old 12-27-2013, 12:09 PM   #101
thom4782's Avatar
Really figuring this out requires sacrificing engines.
Didn't Elton John sing a ballad about Sacrifice?
Old 12-27-2013, 12:46 PM   #102
Engine Surgeon
I've sacrificed an engine in less than one minute proving IMS related components and theories. That was a 4,400.00 prototype part inside of an engine that cost 12K to build.
That year we spent over 100K on development, so don't anyone think that you can solve these issues by spinning up an IMS shaft with a dremel tool, or a lathe head.
We are very thrifty doing every single part of the work ourselves from building the engines built with used parts and etc and we still spend a minimum of 50K per year on this stuff, even buying things at wholesale or manufacturing them from scratch. If you want to play you must pay.
Or you just steal someone else's idea, call it your own and advertise the hell out of it until you make a few people believe that it actually works. You'll sell a few but you'll never get the components into circulation, because the distributors won't believe the BS and you won't pass their stringent QC inspections.
True development is part of the game at this level. It takes years and will consume your life.
US Patent 8,992,089 &
US Patent 9,416,697
Old 12-27-2013, 01:18 PM   #103
BYprodriver's Avatar
As Carroll Shelby said: "Ok now break the $hit out of it!"
Old 12-27-2013, 06:43 PM   #104
Originally Posted by Walter White View Post
"Why not just edit the post to include the pictures??"
If you know how please let me know. I can't find any way to either delete or add photos to a post once it has been posted.
"Just remember, according to the Heisenberg principle, just the act of observing the IMSB will cause it to change!?"
Was that Heisenberg? I thought it was some ancient Greek philosopher.
There's a Breaking Bad marathon coming up on AMC soon. But I live for Gold Rush now. Change.
"You think ill be able to identify where the noise is coming from with a stethoscope?"
You can use a length of garden hose. That works pretty good too.
On the vented picture, the vent should go up, and maybe a short section of tubing pressed into the vent hole, going up then bent down like an upside down J to help keep oil from building up in the vent.
Also, realized that the improved bolt has an O-ring that may interfere with my idea. Hopefully it is not too big to interfere.
The Heisenberg uncertainty principle. It's kinda like quantum rocket surgery and stuff.
Uncertainty principle - Wikipedia, the free encyclopedia
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 12-28-2013, 07:26 AM   #105
Revised drawings
Vent and slosh tubes to help keep vent passage clear of oil
Modified bolt to allow new grease injection directly on to bearing, and provide shoulder to keep push-on cages from popping off.
It's all bad
Walter White is offline   Reply With Quote
Old 12-28-2013, 07:31 AM   #106
That's good. I think I will put that on my You Face Twitter Tube Book.
It's all bad
Old 12-30-2013, 08:35 PM   #107
rp17's Avatar
Originally Posted by boxster View Post
This issue is driving me crazy. Today I started the car and stayed trying to listed for any noises. I couldnt hear anything from inside the car. then I went near the rear wheels and also couldnt hear anything. then I crawled under the car, and could hear some light ticking sounds, (tick tick tick tick.....) but I have no idea where its coming from exactly, or if it has anything to do with the IMS bearing. the noise is hardly noticeable. but if you crawl under the car and try to block out the exhaust sound, you can hear it. Any ideas what it could be? does it have to be the bearing? or is it normal for a boxer engine perhaps?
I had a ticking noise at one point also. Had my bearing done not too long ago and my bearing was fine. That of course is without cracking it open. Turned good though. Usually thats a lifter if I'm not mistaken. Take with a grain of salt.
Old 12-30-2013, 09:32 PM   #108
I was just figuring out the minimum and maximum pressure the IM shaft would see if it were sealed with a freeze plug. Using P1/T1 = P2/T2, volume is not a variable. So that would mean that if the bearing is sealed with its own seals, it would see the same changes in pressure over temperature? Venting the shaft would not help? The grease in the sealed bearing will still see the same pressure changes I think.
It's all bad
Old 12-30-2013, 11:20 PM   #109
Nine8Six's Avatar
That is one of many other calculators that we often use for some applications we engineer.
http://www.skf.com/group/knowledge-centre/engineering-tools/skfbearingcalculator.html
Of course Porsche's R&D have designed better formulas, but it could give you a head start selecting a, perhaps?, better bearing than what Porsche initially came us with.
Bearing life, frictional moment, frequencies, viscosity, dynamic bearing load, etc etc...
Old 12-30-2013, 11:22 PM   #110
Nine8Six's Avatar
Lathes are for cutting and don't forget to change your oil often. And your bearing will be just fine!
Old 01-01-2014, 01:30 PM   #111
Even more bad ideas
It's all bad
Old 01-01-2014, 07:47 PM   #112
Engine Surgeon
And just how are you going to machine or EDM that pathway through the flange?
US Patent 9,416,697
Old 01-01-2014, 08:22 PM   #113
Nine8Six's Avatar
It's easy, you vise the part 45degree and you pour 2 drops of 98% H2SO4 in the cavity (sulfuric acid) and wait overnight
Joking aside, that flange will be need to become a quite advanced assembly on it's own if you go this path. I see a 3 pcs (min) flange assembly
Old 01-02-2014, 05:25 AM   #114
Beginner
Jamesp's Avatar
From a machining perspective, eliminate the 45 leg and drill 2 holes, or if you're heart is set on the 45, drill it from the surface and plug the surface hole. In any event, it appears the path of this hole could be simplified.
Old 01-02-2014, 08:47 AM   #115
I haven't had time to cut a flange in half to see where I can drill and where I can't, but I hope it will be a simple matter of drill and plug. Like carburetors are made (now I'm dating myself). I hope to simplify the path after I see the profile.
With the path shown above, I think only one plug would be needed. But since there is so little space between the end of the IM shaft and the flange surface, It may be required to recess the snorkel into the flange surface a little. It is very thick in that area and a trough could be cut for the tube without weakening the flange I hope. I think the snorkel will also have to be a high grade rubber tube in order to get the flange installed.
Edit: Oops, correct, make that 2 plugs (good-eye James)
It's all bad
Old 01-02-2014, 11:03 AM   #116
Engine Surgeon
So why don't we just remove the ball bearing completely and not worry about all this?
Yeah, forgot, I already did that.
It'll be interesting to see whatever you come up with.
US Patent 9,416,697
Old 01-02-2014, 04:41 PM   #117
Single row IMSB flange
It's all bad
Old 01-02-2014, 06:03 PM   #118
Beginner
Jamesp's Avatar
So is the thought to run a pump inside the IMS shaft using the rotation motion of the shaft and the stationary bearing retaining stud? The oil then exits through an open bearing into the crankcase? I'm not sure what type of pump would lift the oil, but this concept is intriguing. Maybe some type of modified stator vane pump? First pumps air to create a vacuum and lift the oil, and then can handle oil as well? That would eliminate any new moving parts, make the stator and vanes part of a new stud and IMS tube closeout? Neat idea. Lots of technical challenges come to mind. Keep going and have fun!
Old 01-02-2014, 06:34 PM   #119
I'm looking at pumping the oil. It would be nice if it could be done. As I see it, the oil only has to be lifted about an inch. There are several types of pumps that may be viable. But yes I have considered the stator type too. Plan B is to be able to pump grease into the bearing. The biggest question now is can a tube fit down into the sump from the flange. Always looking for help. That's why I post the pics.
It's all bad
Old 01-02-2014, 06:39 PM   #120
Engine Surgeon
Always consider the windage that your "fix" may create. Foamy oil has no film strength.
Nothing like solving one problem only to create another thats 10X more critical for the rest of the engine.
US Patent 9,416,697
