11-21-2013, 09:10 AM
#21
James I have had no involvement in designing any IMS fix, neither financial or engineering. I've just followed the subject for years on several forums and been fortunate to talk to some of the developers. I do have a product development background.
I think you meant your message to be addressed to Pedro.
If you did mean it to be to me, I'd choose the product that best reduced risk and expense to me based on the available data at the time I made my choice. Not opinions or theories or marketing from what was the latest product.
We are dealing with 12 to 8 year old drive em till they drop cars, not collectables. Wonderful cars yes but these aren't 956s. I can't see putting $25k engines in a $10k car. Or the latest new IMS kit (and there are more new approaches coming folks) when there are good enough kits which will probably last as long as the rest of the engine will and they are so much better tested to do good and avoid harm than the latest and said to be the greatest. I value 12+ of real world experiences going back 4+ years over a few recent ones. When shopping for a washing machine, I also like the reviews based on long term use more than the just bought it and it is shiny reviews.
Is valuing real world experience fair to the new guys? No. So what. They have to prove themselves. Until then why would I buy into their marketing claims? What if they turn out to not be so good for the engine after a large number have been run in the real world. Low risk and good enough versus maybe great.
It's your decision and your risk and your cash.
11-21-2013, 04:33 PM
#22
Beginner
My mistake. I mistook you for one who was doing the re-design of the IMS to improve the reliability of that particular Achilles heal. Some do, and some comment. Is valuing the opinions of those who do over those who comment fair? No, So what. I'll stick with, value and be one of those who do. That's why I came up with and implemented a unique and logical solution to the problem with minimum modification to the engine. Will it stand the test of time? Seems like it should, but maybe not, and in the end the real value is in the "doing" which is after all what I do. I can't help it.
11-22-2013, 05:07 PM
#23
Jamesp, I hope your approach is successful. Heck, I hope they all are. Time will tell.
11-22-2013, 06:06 PM
#24
Beginner
Thanks, I appreciate it. And you'r right, time will tell, after I get the *^#&#%@$!!! engine back together. I'm going to start a DIY thread on the rebuild, or maybe it will be a GMA (Give Me Advice).
Reason: typo city
11-25-2013, 07:56 PM
#25
Here is my latest 'Bad' idea for a bearing that lives in grease and a shot of fresh grease can be injected at oil change with a grease gun.
It will require a special seal be fabricated to be installed on the bearing in place of the original, with a grease seal like that found on an engine crankshaft.
A grease fitting can be plumbed to a location on the bottom of the bell housing with a zerk fitting for the grease insertion.
I have ordered some bearings with the metal seals to see how they are made and installed. It looks from photos that the metal seals are pushed into the groove on the outer race and then a sharp pin-punch is used around the seal to pin it in place.
11-26-2013, 10:57 AM
#26
Originally Posted by southernstar
Yes Tony, the Vertex roller bearing replacement has been discussed here previously and the consensus seems to be that, in spite of the obviously greater surface area of roller bearings, they are ill-suited to the IMS application: roller bearings are not intended for, nor are they capable of dealing with the thrust loads that the IMS is subjected to.
Brad
A couple of thoughts that I have on this.
No I do not think that the above pictured IMS bearing is a quality, well thought out piece of equipment. Yet, I do want to add to Brad's comment about roller bearings not being designed for thrust loads. While this is true it appears that this product has integrated plain bearing style thrust washers into the bearing races.
Do I think their design will work? Probably not because they look like low grade, 5 cent parts. But, I'd sure love to hear someone try it and so I can see the pieces when their engine goes.
On another note, I have 4 engines sitting in my garage with spun bearings or d-chunked cylinders. Not a single one has a bad ims bearing. I've pulled several ims bearings and never found a single one that exhibited any play. While yes the IMS bearing is something that goes out on some cars, I think if you drive these things hard the IMS bearing is the least of your worries.
Anyone ever seen the bearing at the front of the ims shaft go out? Of course not, its a plain bearing. All it is, is the steel ims shaft riding in the aluminum casting of the oil pump.
I think from a releability stand point Raby's IMS Solution (the one that utilizes a plain bearing that is force fed oil) is the best idea to date. It's not a coincidence that the only ball bearing in these engines is commonly a failure point. Ball bearings require less lubrication and provide less drag, but wear out faster in my experience and are more susceptible to debris. So then the only problem with the IMS solution is is it's cost. But I guess that's up to the consumer to gauge the value of their engine.
1999 Boxster 3.4L
2007 BMW 328i
1992 Jeep Wrangler
11-26-2013, 04:22 PM
#27
I have heard this many times and while I do not disagree at all, I think it may very well be a matter of the chains throwing much more oil around and creating much more oil mist in the area of the IMS bearing at high RPMs. At low RPMs, the oil that the chains pick up stay on the chains. So it may still come down to just lubrication.
Chain saw bar oil has ingredients in it that keep the oil on the chain, and not flying off at high RPMs. On our Porsche motors, we want the opposite.
One thing I have thought about. How many ball bearings do you see fail in transmissions, wheel bearings, motor cycle engines, the way IMS bearing fail . While they may wear to a point of needing replacement, I don't recall seeing the complete failures in these bearings that the IMS bearing seems to exhibit. When the bearings are bathed in grease or oil, complete or catastrophic failures are very rare.
11-26-2013, 04:52 PM
#28
Engine Surgeon
But Pedro's video shows centrifugal force throwing oil AWAY from the IMSB area? Not that I agree with that, but your hypothesis states the opposite.
The M96 bearings LOVE RPM because it helps unload them, the M97 bearings hate it because the components spin too fast. M96 bearings fail on the street, M97 bearings fail on the track and seldom on the street, very seldom. Load is the evil constant.
US Patent 8,992,089 &
US Patent 9,416,697
11-26-2013, 05:14 PM
#29
jakesbox
For Jake R...and just out of shear curiosity, you have put in so much time with these engines. I have the upgrade you all developed and glad I did it. That was 1,000 miles ago. We see a lot of talk in a lot of our threads about these neat little cars never being collectible. I am curious what your thoughts are on that topic. I assume most wont replace the IMS and we will start seeing a ton of failures from this as well as other parts, but do you eventually think the early survivors might actually start to hold some value? Again..just curious. You have a ton invested in these motors and realize they are not just boxster specific motors...
11-26-2013, 05:35 PM
#30
Engine Surgeon
Its so hard to say what will happen with the value of these cars. The IMS issues and all the other deficiencies have scarred them heavily. I'd like to think that the cars will have price increases over time, especially with fixes for the major issues easily attainable today.
I can't imagine a "vintage Boxster" and out of the 32 cars that we have on our schedule for engine reconstructions only two of them are Boxsters, the rest are 996/997 or Caymans. Thats much different than the old days when we started this, back then it was rare to see a 996 here. hell, I can't imagine a "vintage 996" either.
I am not betting on the cars holding value, so in the December issue of Panorama you'll be introduced to "Cayman X" and our DFI (post 2009) engine program thats now 4 years in the making. Its always about getting into the next big thing before the next guy :-)
Thats why we went straight to 4.2 liters from the factory 3.4!
US Patent 9,416,697
11-26-2013, 06:08 PM
#31
jakesbox
Thanks for your insight. I didnt buy mine to collect but will keep it in as great of shape as possible...seems like the only thing to do is keep it bone stock and enjoy and move on or build a big ass motor and really enjoy it for what it is.
11-26-2013, 08:59 PM
#32
In the early 80's no one gave much thought to vintage 914s. They were just used cars. Time will tell.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
11-27-2013, 05:28 AM
#33
I am not familiar with the video you mentioned, but it would be nice if the oil would sling off the chains, but stick to the bearing.
When I was experimenting with getting oil to a bearing spinning at 4 - 6K RPMs, I was getting the idea that the bearing wasn't getting any oil at all. I would drop a drop of oil into the race of the spinning bearing and it would instantly vaporize. I don't think the oil ever even got to the contact surfaces.
11-27-2013, 05:46 AM
#34
Engine Surgeon
He's posted it in several threads. In all your research I can't believe that you haven't found it.
US Patent 9,416,697
11-27-2013, 05:48 AM
#35
Is the bearing under load while accelerating?
Can you ask a more specific question? The following will clarify why I am asking.
It seems to me that the bearing is under load so long as the engine drive chains are moving. I would think the substantive issue is just how much load does the bearing bear under different operating conditions. The hypothesis I am about to advance is pure educated guessing on my part.
My theory is that forces create load - centripetal due to rotation and vibrational. At constant RPM, the bearing experiences some degree of load, say X. As acceleration increases RPMs, I think the loading increases as the chains increase rotational speed of engine components. At higher RPMs, however, the vibrational loading component decreases because vibrational amplitudes don't have time to reach their full heights.
11-27-2013, 07:42 AM
#36
I am not clear on the vibration part. Is that vibration of the IM shaft, or the bearing components.
Here is some information I found that touches on rpm and lubrication-
" The engineer’s initial thoughts were that the ball-separator failure led to bearing collapse, but after analysis of said IMS bearings, it would appear that bearing wear/fatigue spalls lead to separator wear and outer race failure. Separator failure and bearing collapse causes catastrophic failure of the mounting bolt(s) and IMS/timing chain components. The first recommendation was to use a bearing without seals and secondly to use a higher viscosity oil (with greater film strength). More frequent changes will also improve lubrication quality. An oil with extreme pressure additives like Moly might also further assist in increasing bearing life. Higher rpms also increases bearing life as this lessens the viscosity requirements of the lubricant to maintain EHD lubrication, also providing a reasonable explanation of the lack of IMS failures in tracked cars or those driven "like they were stolen." Likewise, far more failures are found in engines with low mileage that are garage queens and never driven to their full protential."
Source: PORSCHE Intermediate shaft upgrade kit for PORSCHE BOXSTER ENGINE 986 AND PORSCHE 911 996 ENGINE
I have to admit I am stuck on rolling bearings for the IM shaft. I just keep asking myself why Porsche insisted on using a rolling bearing for so long. Was it because it was the best fit for handling dynamic forces that they were not able to engineer out of their production parts.
11-27-2013, 10:19 AM
#37
Two thoughts...
Vibration may not be the best word. I used it to make the point that IMSB is not purely rotational. There are side forces that contribute to loading. The article you referenced hit the nail on the head - spalling is is the path to failure. The rate of spalling is inversely proportional to loading, which explains the higher OEM single row failure rates. That is, higher single row point loadings lead to increased spalling compared to dual row bearings
In some sense, the IMS Solution is the biggest roller bearing possible. It provides the largest surface area to distribute bearing load.
11-27-2013, 10:10 PM
#38
At high rpms, ball bearings prefer an oil vapor. Take a look at ball bearing turbos, albeit at a much higher rpm, they fog the bearings.
1999 Boxster 3.4L
2007 BMW 328i
1992 Jeep Wrangler
11-28-2013, 04:36 AM
#39
Beginner
Reading bearing manufacturer data on lubrication shows that high rpm requires lower viscosity (thinner) lubrication, and low RPM requires higher viscosity lubrication. It was explained that that the lubrication has to "be in the way" when needed, and also be able to "get out of the way" so the bearing elements can pass. This supports longer bearing life in aggressively driven cars that have engine oil in the bearing. So to the folks out there with 200K+ on their cars, we know how you drive.
11-28-2013, 08:37 PM
#40
Originally Posted by Jamesp
Reading bearing manufacturer data on lubrication shows that high rpm requires lower viscosity (thinner) lubrication, and low RPM requires higher viscosity lubrication. So to the folks out there with 200K+ on their cars, we know how you drive.
Or they drive at really low revs with really thick oil......
2001 MV Agusta F4.
