Old 10-27-2013, 01:34 PM   #1
P0301 Code - after spark plug tube replacement
Yesterday I replaced the Spark plug tubes on the right side of the engine.
After that the check engine light started flashing and it is running rough.
I bought a Actron 9125 code reader and I got the following (I may be giving superfluous info)
P0301 misfire
5INC
Mil On
Monitors
02 Sensor
O2 Heat
Catal
Evap
Sec Air
3 Ready
Misfire
Fuel Comp
I think the pertinent message is the P0301 misfire code.
I don't even know which is "cylinder one" - could it be the front right cylinder?
I do not think I damaged the coil, but it may not have plugged back on to the spark plug well. I do know that the connector came off on the front right coil so perhaps I didn't get it plugged back in correctly.
Also, I broke in half the top AOS tube (duct taped it so I could test run it) and wonder if that could have something to do with this.
Any recommendations are welcome!
Thanks.
utkayaker is offline   Reply With Quote
