Old 10-20-2013, 07:59 AM   #1
The Radium King's Avatar
boxster viagra
new way to stiffen things up ...
Transmission & Engine Mount Insert Kit
Old 10-20-2013, 01:32 PM   #2
woodsman's Avatar
that oughta' put a little spring in your step!
Old 10-20-2013, 01:36 PM   #3
ganseg's Avatar
Would this work on an engine mount that is shot?
ganseg is offline   Reply With Quote
Old 10-20-2013, 01:49 PM   #4
woodsman's Avatar
well it would to some degree but a new one at Suncoast Porsche costs the same-$130!
Old 10-20-2013, 03:21 PM   #5
get the 987 mount - stiffer than the 986 and a direct fit.
Old 10-20-2013, 03:39 PM   #6
If your engine mount is shot you should replace it with a new mount. Problem solved.
Old 10-20-2013, 06:58 PM   #7
Recently replaced engine mount on 2002S w 46, 000 m. Tremendous improvement in shifting and handling. Also replaced transmission mounts at the same time. Engine mount had actually broken. I think the rubber just goes bad w age.
opus69 is offline   Reply With Quote
Old 10-20-2013, 07:14 PM   #8
I find it hard to believe that this design would firm up the mount yet not send a lot of vibration into the car. As Radium King said, the best tradeoff between firmness and vibration is the stock 987 mount.
Old 10-21-2013, 08:57 AM   #9
BYprodriver's Avatar
Looks like if it is shaped properly it should limit, but not eliminate, movement of the engine. I want to try it, but it will probably be a while before I get to it.
