Old 10-24-2013, 12:05 PM   #11
Originally Posted by Steve Tinker View Post
Does it really, really matter if the bearings are splash, force or mist lubricated
Absolutely! Bearings are NOT happy if they are not lubricated. We've had this before at my factory - a piece of equipment is returned from rebuild. It's not lubricated by the rebuild shop. We assume it is and put it in the machine. How long do you think it lasts? Not long!
This is from the LN Engineering IMS Retrofit website:
See that tiny slit between the IMS shaft and the IMS bearing cover? That's what the IMS Retrofit depends on to get oil bath, splash, or mist lubrication from. That's what scares me about that solution - there is not a great, reliable path for consistent lubrication. Now if you could pump in oil from inside and just let it drain out of that slit you would end up with the area between the end of the shaft and the cover filled with oil - thus flooding the bearing at all times. Both the TuneRS DOF and IMS Solution plain bearing put oil inside and drain out of this slit. I don't see why aeration or anything else would be a concern in either application.
Kirk Bristol
