Old 09-30-2013, 07:20 PM   #21
thom4782's Avatar
Data provided in the IMS class action suit indicated single row IMS bearings fail about 8% of the time whereas double row bearings fail 1% or less. Structural weakness is the best explanation for the difference in failure rates with all things being equal except the 1) the relative amount of contact surface areas of the balls and races of the two designs and 2) IIRC the thickness of the bearing support,
Even the dual row bearings, however, do fail so structural weakness cannot explain all failures. I believe compromised lubrication probably explains a lot of the rest and the 1% underlying rate. This phenomena happens when acids and particulates in engine oil causes bearing seal degradation that allows oil to mix with the bearing's grease. The combination lubricates very poorly and after some time the bearing fails.
Old 10-01-2013, 03:48 PM   #22
THOM4782 based on all the info at hand,if u had an 06 thru 08 with the newer large single row bearing design that could not be removed without splitting the cases would u do the DOF mod or just leave it alone and change out the oil more frequent, especially at end of season before storage (if needed).
moresquirt is offline   Reply With Quote
Old 10-01-2013, 09:08 PM   #23
thom4782's Avatar
I just don't know enough about the large single row bearing to offer a useful recommendation myself. With its low failure rate, I wouldn't worry and, if I did worry, I probably would simply change oil frequently.
The vendors sharply differ on the question of efficacies of splash oil (the IMS Retrofit website's oiling section) and DOF (the TuneRS site and Pedro's video). I don't know whether they would hold these same opinions when opining about the large single row bearing.
My car is a single row bearing and when I get to it I plan to install the IMS Solution.
Old 10-03-2013, 04:41 AM   #24
Daniel, well said.
My attitude was I'll replace it with an engine that has all 20+ failure points addressed because I can afford the down time, the emotional cost and the expense. Risk excites me and failure is familiar in my former profession. So I'd be willing to try lots of new solutions thought to be better in the same engine considering that most of those fixes have been out in the real world for several years on dozens of cars. Not for everyone.
What most of the folks are searching for (those that doesn't fit my profile) is what is the best means of eliminating risk? How to best balance the expense versus probable risk? New with great sounding theory versus well tried? Now or can I wait 10k miles? Oh, and while you have the transmission out, what else do you do that makes sense? How much is all this going to cost me? And how much new risk am I taking on (installer error, ultimately failed theory, random part failure) when I do what I decide to do?
Of course once you have the IMS solved (you think) some other random failure could bite you. Been known to happen.
The installer is enormously important. My wife just had a knee replaced. She searched 6 months to find the one Doctor that all patients with failed knee implants went to for correction. Took 20 minutes less than estimated. Successful. Experience matters inside the engine too whether designing a fix or just installing one.
Old 10-03-2013, 12:20 PM   #25
Engine Surgeon
Ask 10 people and get 10 different answers. Some of us have IMS Retrofit components applied in numbers greater than ten thousand. Others do not.
US Patent 8,992,089 &
US Patent 9,416,697
Old 10-03-2013, 01:08 PM   #26
Jake, there is no arguing that with respect to the retrofit bearings. Nor is there, IMO, any argument that your IMS 'solution' is an elegant bit of engineering that effectively replaces the problematic IMS ball bearing with a bearing that mirrors the one on the other end of the IMS - one that has never been known to cause problems. You then, of course, provide for the required oil feed to the new bearing. While I suspect that the number of 'solutions' installed in customer cars to date is nowhere near 10,000 (and customer use would also be for less than a year), I am nevertheless satisifed that it will work as advertised based upon common sense.
Intellectually, however, I also think that the DOF plus a replacement bearing (in engines prior to the large single-row bearing), or just the DOF in large single-bearing engines, should prove to be an excellent solution. With proper oiling, I do not see how a ball bearing IMS bearing (and particularly, a dual row ceramic IMS bearing for the earlier car) should fail. Which 'solution' would I have more confidence in? For the single-row bearing engines, yours, hands down. For the later large bearings, if they still appear sound, I wonder if the cost of disassembly would be justified.
Brad
southernstar is offline   Reply With Quote
Old 10-03-2013, 03:19 PM   #27
Excellent point Brad,but based on testing done by Raby years ago ,it dosent sound like a good idea,he has his reasons and i am sure would have come up with something similiar in design if he felt DOF ect had some merit.He already has direct oil feed at part off the solution so he knew about that benefit and simply removing the outer bearing seal would have been a simple soulution that he obviously decided againt for reason addressed below.
Having Jake chime in on this topic has definately got me questioning DOF as the final fix.I just wish i dident need to pull and split my motor to install.But thats the deal!
Old 10-03-2013, 06:59 PM   #28
thom4782's Avatar
There are many examples where common "engineering' sense proved disastrously wrong: the Titanic, the Tacoma Narrows bridge, the Challenger space shuttle, etc. Moreover, people assume that more oil is better simply because it's more oil. However, a fire hose doesn't water a small vegetable patch any better than a garden hose; a 10' deep swimming pool doesn't make a swimmer any wetter than a 5' deep one.
BTW: where are the facts / data that suggests dual row bearings fail because they don't get enough oil. Remember these failing bearings are sealed and therefore internally lubricated. Pumping external oil onto a sealed bearing won't help much if at all. The fix is to replace the OEM bearing with an unsealed dual row one. To date, there are no dual row LN Retrofit bearings failures even though these retrofits are splash oil lubricated. DOF contends it will extend the operating lifetimes of unsealed bearings, but the vendors won't say by how much. If they have, I haven't been able to find the estimate.
Old 10-03-2013, 07:06 PM   #29
Engine Surgeon
Guys,
Nothing in the mechanical world is perfect. Every mechanical design has its compromises, whether they are cost, packaging, fitment or complexity.
I respect all competing technologies and those who have developed them. Without those types of things there would be nothing to inspire me to continually evolve the components, processes and tools. Its also a free market place and we are all given equal opportunities to create what we feel is the best way of solving any given problem.
The biggest compliment I've had in a while was ordering some "competing technology" (to evaluate on the dyno) and finding that the IMSB extraction tool that I invented was being bought from a distributor and then remarked and re-sold by the competitor, as their own. Thats nothing new, and to be expected.
Thats ok, the first generation tool is now out of date and the new tools are the way of the future. The current tools will soon go away and the competitor will have to do something else, or sell a tool with my trademark on it. The processes have never been easier and safer to carry out both from an extraction and installation point of view than whats made possible by this tool. Remember, without the tools and processes that I created these "options" wouldn't be out there; because you couldn't extract the bearings (at least the dual row IMSB) to allow for retrofits. When I developed this procedure it was thought to be "impossible" or black art. The day I posted the first IMSB retrofit procedure on my website it went viral and the site had over 30,000 unique visits in a 48 hour period. Today people forget about the conversations of yesterday where people were arguing about whether or not an IMSB could even be extracted. Then there was no other choice, either you bought what the pioneers offered, or you didn't buy anything. Its rather funny that one of the developers of competing technology actually utilized the LN IMSB in his own car prior to developing his component, but I respect him for admitting that. We even tried to help the guy out.
And yes, 2014 will find yet another IMSB retrofit evolution release. In fact, the "faultless tool" is required to install it. This unit is developed as a mid price point retrofit not costing as much as the IMS Solution, but offering more life than any single row 6204 style bearing. The IMS Solution solves the problem, but it isn't for everyone, primarily due to cost and the extra special care required to properly install the component.
Some contend that the bearing isn't the problem and that lubrication is. We contend that the OEM ball bearing and its multitude of moving parts, that lead to engine-wide collateral damage after bearing failure is the problem. Its okay to disagree and none of us are really ever going to be proven right, or wrong, so it really doesn't matter.
US Patent 9,416,697
Old 10-03-2013, 07:45 PM   #30
Johnny Danger's Avatar
Jake,
Are the rumors that are spewing from the Vatican true - that you're coming out with the much anticipated "IMS Absolution" ?
Old 10-04-2013, 05:00 AM   #31
Beginner
Jamesp's Avatar
Bawa Hahahahahahahaha!
Old 10-04-2013, 05:56 AM   #32
Engine Surgeon
Jake,
We already released it.. We kept it simple and just called it the Solution.. But not everyone can afford it, so a semi version of it is being released... It's not a plain bearing, though.
I'd like to have a hi-res version of your image to put upstairs in my admin area :-)
US Patent 9,416,697
Old 10-04-2013, 08:54 AM   #33
Send me a pm with an email to send it to.
Old 10-10-2013, 02:33 PM   #34
ppbon's Avatar
It is an oven
The IMS tube is not an oven and is the same heat as all the other oil in the engine so all this talk of burnt oil in the IMS tube does not make sense.
It's just a crock pot instead of a convection oven.
I have seen and smelled a couple of dozen cars in which the oil that came out of the IMS was as thick as molasses and stunk like nothing I'd smelled before.
We had to dissolve it with carb cleaner.
If you NEVER change the oil in your car it will gunk up and do the same.
The oil that seeps into the IMS is not replenished and that's why it's cooked.
Happy Boxstering,
Pedro
ppbon is offline   Reply With Quote
Old 10-10-2013, 02:36 PM   #35
ppbon's Avatar
I don't agree ...
Originally Posted by thom4782 View Post
Structural weakness is the primary reason single row bearings
fail more frequently than double row ones. DOF, without bearing replacement, doesn't help this problem.
... that they fail because of structural weakness.
The reason, IMNSHO why they fail sooner than a double-row or the larger single row is because they have less surface area (between the ball and the race) and when the acid in the burnt oil starts to pit the surface it will fail sooner.
The bearing itself is strong enough to sustain all of the loads the engine will subject it to.
The problem, once more is the lack of proper lubrication.
YMMV.
Happy Boxstering,
Pedro
Old 10-10-2013, 05:38 PM   #36
Engine Surgeon
This supports our point of view, that the problem IS the bearing.
And of course, there's still one very important fact concerning the 6204 bearing that no one has thought of, and its critical. Those who have attended my class know what it is, and they have held the bearing in their hand and manipulated it in two ways, then observed this critical factor. This is something I only share one on one and will never post anywhere. I am considered putting it into print in my M96 Engine Bible, but haven't made my mind up yet.
That single factor is what makes the difference. Every single Bearing Engineer we have consulted with has brought the point up, but we considered it before they did.
US Patent 9,416,697
Old 10-11-2013, 04:16 AM   #37
Hmmm.... could be how it handles thrust loads?
Old 10-11-2013, 07:39 AM   #38
Sure Jake,show the chrildren the icecream but don,t let them have a lick!!
Old 10-12-2013, 08:18 AM   #39
I like your analysis. My thinkingis that you can reduce the Cayman Island factor by choosing an approach that has a track record established by thousands of experiences. Which means, you either live with the OEM odds that Porsche has admitted to (based on 100k plus experiences) or the LN bearing (based on 10k plus experiences). You might possibly do better in the long run with one of the oiled approaches but the statistics aren't there yet (not enough installs, not enough miles) so the odds of doing better really can't be known.
And choose an experienced installer no matter which kit you choose.
Old 10-12-2013, 08:27 AM   #40
Engine Surgeon
The guys in my class today, here in Atlanta will learn about this tomorrow.
Otherwise its not shared or even spoken about. Plus, I want to see how long it takes the "expert opposition" that has attempted to join our ranks in the past year or so to finally figure it out. We've only known about it for a decade.
I am currently attempting to see if this was part of the discovery documents for the IMS Bearing Failure class action lawsuit. I'd be willing to bet that its not.
US Patent 9,416,697
