01-29-2012, 01:22 AM
#1
19X11" on Boxster 986 without any mods
01-29-2012, 02:09 AM
#2
Originally Posted by madmods
Hey guys, first who does this Boxster belongs too? if anyone knows
RW5 Porsche Rim - Roderick Wheels
I am talking to these guys about getting a rear rim done in the 19X9.5" or 19X10". Unfortunately they only come in 19X11" and that's it. However, these same guys, obviously wheels "Pros", and they assure me that the 19X11" will slide on the 986 without any modifications at all. For info.... the rear tyre on this advertised Boxster is a 295/25/19 (factory Porsche 996).
If this all true, and can be confirmed, I think I will be shooting these guys my CC number and graba set in silver.
So how can we remotely confirm this 19X11" is a "Go" for the little roadster?
Hi,
the RW5 rim in 19x11 offset 40 fits with a 8mm spacer, but i donīt think, that`s possible with a 295 tyre... however... in this configuration only a 265 or 275 should possible, because the 295 would be scratch outside on fender and perhaps inside on the strut. If you want to get lowering your boxster, keep in mind that each rear fender must be widened for 1" and needs a more negative camber!
www.dynamic-speed.com
01-29-2012, 06:07 AM
#3
Holy ********************, this recurring question regarding whether or not a 19 X 11 wheel will fit on a 986 boxster has become nothing short of a Seinfeld episode . Once again for the record, there's no way an 11 inch wide wheel will properly fit on a 986 boxster regardless of what the offset is ! . Tell the wheel "pros" at Roderick that they would have a better chance of fitting one up their a** than they would on your vehicle. I'll even provide a dab of Swisswax to ease the passage .
* On second thought, maybe you should get a set after all and make a video of the install ! This will finally put the issue to rest when everyone sees that you had to take a sledgehammer to your fenders in order to make them fit !
Don't worry
I've got the microfilm.
01-29-2012, 06:28 AM
#4
WV Boxster
I have not tried and never will. I for one do not like thhe look of anything that big on our little Boxster.
If you look at the picture from the rear you can see the wheels are outside the fender. So as far as fitting yes they might but ----- how would you drive it any movement/ travel up of the rear wheel would cause contact with the fender. I would not want my last two inches of my tire rubbing my fender at 70mph for any length of time.
So if you intend to park car they fit but again to me look bad on car.
If your not LIVIN now, then when?
01-29-2012, 07:08 AM
#5
01-29-2012, 07:10 AM
#6
01-29-2012, 07:11 AM
#7
19 x 11 is possible but only with a 265er tire and extensive reworking of fender, bumper, a lot of negative camber and so on. i have 18 x 11 on my own, with very low suspension and it it fits and works perfect in all situations. but it is very tricky, to widening the fenders... a little bit to much and the fender gets totally damaged.
01-29-2012, 07:15 AM
#8
Originally Posted by SpyderRS
Oh oh oh.... sick, no?? anyone??
Nice work right there! Tons of thanks for that that pic btw
01-29-2012, 07:18 AM
#9
here you can see it better...
01-29-2012, 07:24 AM
#10
01-29-2012, 07:25 AM
#11
i forget to tell... fenders are widened without any painting works...
01-29-2012, 07:33 AM
#12
01-29-2012, 07:39 AM
#13
Again, brilliant and clean work. Love the fireblade in the back  here is my blade and the little roadster!
Nice!
Which sizes you drive at the moment?
#14
01-29-2012, 07:42 AM
#15
01-29-2012, 07:55 AM
#16
Temp wheels really.... 19X8.5 (235/) and 19X9.5" (265/). Fuggly as hell but the main thing is they roll for now!
take the tires for the RW5, get a min. -2°30 negative camber and widening the fenders.. so it will fit with 19x11 et40 plus 8mm spacers!
01-29-2012, 08:00 AM
#17
01-29-2012, 08:03 AM
#18
You bet. The request for taking $2,000 off the year's entertainment budget is already sitting on my wife's desk  Fingers crossed!!!
lol
wish you good luck!
01-29-2012, 08:09 AM
#19
01-29-2012, 08:15 AM
#20
haha indeed! but enjoying every moment of being poor believe me..... and unlike most of the expansive and rich people that I know, I do have genuine friends!!!! Priceless
Wish you all the very same Spyder and tons of thanks again for the pictures and help here. Owe you one
No problem, buddy! if you need some help... ask for it!
