Old 05-30-2013, 01:56 AM   #2
The pinion bearing is the last thing on the counter/output shaft. It will require everything pressed off the shaft in order to get to the bearing.
Try Callas Rennsport. There is a special plate that holds the shaft centered and vertical for pressing. I am sure someone could rig up a device, but the special tool is really nice to have when pressing everything back on.
Skoot
Skootnasty is offline   Reply With Quote
