05-23-2013, 04:00 PM
How to replace a variocam actuator
My shop just called me up and told me the one of the variocam actuator isn't responding (I can't remember which one). They're telling me they need to pull the motor to replace it which is a drag. I'm hoping there is a work around, does anyone have a write up or know whats involved? I'm told the valve cover has to come off which can't happen unless the engine is out of the car. I remember dropping the engine quite a bit when I did the engine mount and I think I could pull the cover without taking the whole engine out. Thoughts?
2003 911 C2
NASA HPDE Instructor
05-23-2013, 04:32 PM
You can pull the valve covers in the car. Did it at the shop today. I would pull the solenoid and clean out the valve body of the actuator. I have seen trash get in there an lock the valve up.
Blake Meredith
Flat 6 Innovations Engine Shop Foreman
05-23-2013, 04:33 PM
Porsche dealers don't drop the engine to replace the solenoid or actuator. You need to know if the code indicates it's a solenoid problem. Sounds like you need a new shop too.
What year Box?
05-23-2013, 04:36 PM
The car went into the shop for a different reason, I never noticed the cam problem. Apparently one bank isn't actuating at high rpms. Is it possible it's stuck because its sitting and will loosen up? It's been sitting for 3 weeks. I know bmws hydronic valves can stick or get air in them when they sit.
2003 911 C2
05-23-2013, 06:00 PM
The point is, they're telling you that the motor needs to be removed when indeed it does not... Find another shop and get a second opinion.
At the very least, ask them why they want to remove the engine.
05-24-2013, 03:24 AM
I'm shocked they would mislead me, it's a great Porsche only shop. I'll ask them about it his afternoon an see what they say. It sounds like i should be able get someone to fix it do around 1500 if the interwebs are true. Is it possible that I bought the car like this and never noticed it? I wonder if I've been dragging anchor thIs whole time
It's a 97 by the way
2003 911 C2
05-24-2013, 03:45 AM
It's possible. The solenoid and contacts may just need a good cleaning. Have them follow Bam's advice first. If that doesn't work then look at the solenoid. I don't believe there's a need to remove the engine or the valve cover to clean the solenoid or even replace it.
The idea that they want to remove the engine right out of the gate would concern me a great deal. I would definitely ask him why, and I'd do so without letting him know that you've been told otherwise.
It could be miscommunication or he could be trying to soak you...many of us have had that experience.
05-29-2013, 10:01 AM
I just picked up all the parts to knock this out. How much time am I looking at for he repair?
2003 911 C2
05-29-2013, 11:46 AM
We want to hear the end of the story - What did the shop have to say when you asked them about needing/not needing to remove the engine?
06-08-2013, 10:22 PM
The Legend
Hi truegearhead,
I'm looking at a similar repair with my VarioCam Actuator on a 98 and was thoroughly disappointed with the lack of documentation for this area (in the Porsche shop manual or online). I'd appreciate if you might take the time to snap a few pictures as you go through your repair.
EDIT: Where did you get the parts and how much did you pay? What special tools did you purchase (ie holding down the cams)?
Best of luck with your repair.
02-20-2014, 11:10 AM
Why people so often describe a problem, ask for help, gather opinions and suggestions and then just vanish without providing any feedback about the problem solution. Next time someone (like me right now) is looking for threads about the same problem and hit dead ends like this. Really frustrating. People are spending own time to read about your issues, think and even research and post responses. At least be courteous enough to provide feedback about the solution (if solved or still unsolved).
02-20-2014, 12:14 PM
Well said, sir.
'99 black 986
02-20-2014, 03:02 PM
Well, that being said, I recently had a similar problem. After a spirited run, my car wouldnt idle and bogged at low rpms. I took it to the shop, plugged in the durametric, and checked the actual values.
Timing:
Cyl 1-3- 6.2 deg
Cyl 4-6- 19 deg, and fluctuating!
So I immediately assumed something was wrong with the cam timing, so in a panic, I pulled the valve covers off WITH THE ENGINE IN THE CAR, without lowering anything.
Pulled off the cams for cyls 4-6, and couldnt find anything. I took the cam tensioner apart, still nothing. So I took it to the parts cleaner and gave it a thorough lookover on the work bench. The solenoid worked fine with 12V applied to it. As for the piston it presses down on? It was stuck in the actuated position. I pulled it out with a pair of pliers, cleaned it again, and after pressing it a few times, it got stuck again. I had a known good unit on the shelf, so I installed it.
I also installed the cam-brake kit on both sides, which comes with the two chain guide pads and an O-ring. I also changed the spark plugs.
I started the car up, and it ran perfectly. Cam Deviation was +1 and +4 degress, within tolerance and good enough for me.
02-21-2014, 08:43 AM
I just finished up replacing the #1 bank actuator. its a time consuming job. There is a great write up in the 101 projects for your boxster. But if you don't have that handy I'll walk you through it.
02-22-2014, 09:22 AM
Le lien ne marche pas !
2003 Boxster S
02-25-2014, 10:12 AM
02-26-2014, 05:24 PM
Since someone revived this thread from the grave I'll add an update. My computer was throwing the variocam code(which I saw). And I replaced the vario-cam which didn't fix the code, the car also continued to engage the variocam after the fix...I then changed out the mass air sensor and it resolved the code. I'm not going crazy, Indy shop verified. Maybe it was a fluke. I hear mass airflow sensors create all kinds of odd problems though.
2003 911 C2
