Old 04-14-2013, 05:21 PM   #1
DP-99-986
Send a message via Skype™ to David Poulson
Litronic
Are the Xenons supposed to turn off when the high beams are on? If I flash high beams, both lights go on... if I put on the highs, the Xenons turn off. Any ideas? Thanks
David Poulson is offline   Reply With Quote
Old 04-14-2013, 06:16 PM   #2
jsceash's Avatar
They should stay on Mine rotate up and left as the high beams are turned on as well.
Old 04-15-2013, 05:06 AM   #3
audisnawb's Avatar
Send a message via AIM to audisnawb
I noticed the same thing with my Litronics, David. It must be how they function.
I assume, the HID stays on when you flash the high beams so it does not put wear on the bulbs and ballast, however when you perminantly put the high beams on, they switch off
PRESENT:
SUMMER FUN: 1999 986 Porsche Boxster Metalic Black on Sierra Beige
WINTER BEATER: 2007 BMW 530xi
PAST: 2000 986 Porsche Boxster Biarritz White on Sierra Beige
audisnawb is offline   Reply With Quote
