Old 02-17-2013, 06:06 PM   #1
I am my own mechanic....
Timco's Avatar
Clutch jobs / shift lever leak
Hello all.
My 04 S needs a clutch. 550 body.
If I just did a clutch on my 2000 Ranger, shoud I be able to do the Boxster?
Also, I have a small leak from a shift lever. Lower, or rear I think. Can this be fixed?
Tim
'08 VW Touareg T-3 wife's car
Old 02-17-2013, 08:12 PM   #2
1999 base
Meir's Avatar
Hello all.
Tim
Never did a clutch job on a ranger. In fact, I never did a clutch job on any car befor I did it on the box.
So I assum you will do just fine
Get the 101 and the Bentley books. Read about the procedure and you will be good.
This is also a good oportionety to concidure IMSB and RMS retrofit.
As for the leaking lever, are you referring to one of the levers located on the trans?
Old 02-17-2013, 09:23 PM   #3
Timco's Avatar
Yes. It's a shift lever. Good to know a clutch is not that bad! I have both books.
Thanks.
