Old 02-17-2013, 07:12 PM   #2
Meir
1999 base
Meir's Avatar
Hello all.
My 04 S needs a clutch. 550 body.
If I just did a clutch on my 2000 Ranger, shoud I be able to do the Boxster?
Also, I have a small leak from a shift lever. Lower, or rear I think. Can this be fixed?
Tim
Never did a clutch job on a ranger. In fact, I never did a clutch job on any car befor I did it on the box.
So I assum you will do just fine
Get the 101 and the Bentley books. Read about the procedure and you will be good.
This is also a good oportionety to concidure IMSB and RMS retrofit.
As for the leaking lever, are you referring to one of the levers located on the trans?
