Originally Posted by Meir
Never did a clutch job on a ranger. In fact, I never did a clutch job on any car befor I did it on the box.
So I assum you will do just fine
Get the 101 and the Bentley books. Read about the procedure and you will be good.
This is also a good oportionety to concidure IMSB and RMS retrofit.
As for the leaking lever, are you referring to one of the levers located on the trans?
Yes. It's a shift lever. Good to know a clutch is not that bad! I have both books.
Thanks.
'08 VW Touareg T-3 wife's car
