Old 12-16-2012, 07:12 PM   #1
1999 base
Meir's Avatar
oil pan bolts.
when trying to fix an oil leak from the oil pan, i discovered broken bolt.
i was thinking to reseal the pan and replace all 13 bolts.
i ordered the bolts among some other parts, but sunset had only 2 bots in hand, so i took them.
today i was planing to remove the broken bolt, and complete the task.
i cleaned all the bolts i have (that i previously removed from the pan), and then reached for the 2 new ones i got.
when i looked at it, the two new bolts are shorter then the ones i have.
the new bolt is M6X16. the old is M6X20.
see attached pics.
at first i was sure i ordered the wrong bolt, buy checking at the parts list, it looks like the correct size is the 16mm.
so where the hell those 20's came from?
Old 12-16-2012, 08:08 PM   #2
I would use 20mm bolts if that is what was in there before. Just get any good quality bolt, doesn't have to be from porsche. You are putting a steel bolt into aluminum threads, so you want as long a bolt as possible to help avoid stripping the aluminum threads.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 12-16-2012, 09:34 PM   #3
1999 base
Meir's Avatar
You have a point, but on the other hand, any source I checked shows 16.
I'm really puzzled by that.
Thanks for the advise.
Old 12-17-2012, 12:02 PM   #4
external Torx head
I could swear that the oil pan bolts had an external Torx head...
perhaps too much tequila?
Old 12-17-2012, 12:17 PM   #5
1999 base
Meir's Avatar
i guess.
the ones i have are regular hex head but 20mm long.
all part lists i checked show the same bolt, only shorter.
Old 12-17-2012, 04:50 PM   #6
BYprodriver's Avatar
That's the new design, smaller head = lighter?
Old 12-17-2012, 05:53 PM   #7
1999 base
Meir's Avatar
LOL!
Maybe I should go with plastic. Get extra 2 MPH at top speed
Old 12-18-2012, 08:36 AM   #8
I'm surprised that the steel bolts go into aluminum. I recall from my Navy days that our ship had a steel hull but some of the superstructure (bridge area) was aluminum so the ship wasn't top heavy. And we had to be cautious about how we connected the two because of accelerated corrosion caused by an interaction between the two different metals. I don't recall the details of how we did that as it is approaching 50 years ago but we either used special fasteners or kept the two metals apart by some insulating method.
Old 12-18-2012, 09:44 AM   #9
That's 1 of the reasons all the Porsche engine bolts are plated, with cadmium I think.
I guess the exhaust system bolts are 1 of the few exceptions.
Old 12-18-2012, 10:40 AM   #10
1999 base
Meir's Avatar
i just got the bolt from the local ACE.
i hope it is cadmium plated .
maybe in the future (when i have more input on this subject), i will replace all bolts with the OEM shorter ones.
Old 12-17-2012, 08:07 PM   #11
Carbon fiber. +5mph.
