Old 10-27-2012, 05:33 PM   #1
mistermac99's Avatar
Heater/AC always on low when starting vehicle...can this be changed?
When I start up my 1999, the heat/ac always comes on the low setting, even though I have it turned off when I turn off the engine and get out of the car.
Is there a way to change this setting by changing some sort of code, so it does not come on when the vehicle starts up?
Every vehicle I have owned, you have to turn on the heat/ac, but this one always comes on to the lowest setting when cranked.
Thanks for any help.
1999 Boxster - Arctic Silver Metallic
***As You Think, So Shall You Become***
mistermac99 is offline   Reply With Quote
Old 10-27-2012, 06:23 PM   #2
1999 base
Meir's Avatar
not sure what is your issue, but i can confirm it shouldn't work this way.
if you want, let me know what is the part number of your HVAC control.
i have another one laying around i can send you just to check if yours is faulty (from a 01. so it might not fit).
another option is the ignition switch. any other strange behavior with the electric in the car?
Old 10-27-2012, 08:16 PM   #3
Don't want to replace anything if possible, just wanted to know if this was normal, or if there was something that could be changed in the codes.
Maybe I will ask my Indy the next time we speak.
Not having any issues with the ignition. or any other electrical issues.
Old 10-27-2012, 10:36 PM   #4
1999 base
Meir's Avatar
just to be clear.
i did not offer to sale you anything.
the way you described the behavior of the AC control unit, is not normal.
most chances is, you have a defected unit.
instead of buying one, and then find out its not the problem, i offered to lend you main for the troubleshooting process.
from your reply, i understand you are not working on your car yourself, so my offer is not relevant.
just to make it clear again, the HAVC module is not for sale.
Old 10-28-2012, 07:12 AM   #5
tonycarreon's Avatar
do you have it "Off" or do you have the fan turned down to no bars? (they're not the same)
the display should show "Off".
also, make sure (before turning it off) that "auto" is not selected
Old 10-28-2012, 08:02 AM   #6
I have a 2000 Base Model and the same thing happens with mine. When I start the car, the A/C displays the last temperature setting I had as well as "Manuell", although no bars are showing for the fan speed. This is after shutting the unit to "OFF" prior to turning off the ignition.
Alfieg23 is offline   Reply With Quote
Old 10-28-2012, 01:30 PM   #7
Ex Esso kid
You had to turn it off every start on my 1998 -986 I hated it.
Old 10-28-2012, 03:12 PM   #8
2000 S. Comes on at every start on the last setting. Annoying. But I read somewhere it is normal.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
Old 10-28-2012, 04:43 PM   #9
walt2810's Avatar
Ditto for MY99 - lame design their engineering.
walt2810 is offline   Reply With Quote
Old 10-28-2012, 05:23 PM   #10
Thanks for the information.
Now I won't go chasing a solution.
I guess I will just turn it off after each start, if I don't need it.
While we are on this subject, when I have my heater on, and then decide to hit the defrost button, the fan comes on wide open, and I have to turn it down to a lower setting.
Is this also normal?
Old 10-30-2012, 09:58 AM   #11
walt2810's Avatar
YES, another swell design from the great minds at Stuttgart
Old 10-30-2012, 04:51 PM   #12
Ex Esso kid
Actually, I think that controller was borrowed from Audi
Old 11-01-2012, 09:03 AM   #13
walt2810's Avatar
Great minds think alike. no need to re-invent the wheel
Old 11-01-2012, 08:44 PM   #14
Idaho Red Rocket 3's Avatar
Both my 1998 and my 2000 do that. I have learned to turn on the key then turn off the A/C then finish starting the car. I dislike the setting that way.
2000 Boxster S
Old 11-04-2012, 03:43 PM   #15
gerber28's Avatar
2001 S, I turn the fan speed down until OFF is displayed. Restart later it remains OFF.
gerber28 is offline   Reply With Quote
