Old 10-27-2012, 06:23 PM   #2
Meir
1999 base
Meir's Avatar
Originally Posted by mistermac99 View Post
When I start up my 1999, the heat/ac always comes on the low setting, even though I have it turned off when I turn off the engine and get out of the car.
Is there a way to change this setting by changing some sort of code, so it does not come on when the vehicle starts up?
Every vehicle I have owned, you have to turn on the heat/ac, but this one always comes on to the lowest setting when cranked.
Thanks for any help.
not sure what is your issue, but i can confirm it shouldn't work this way.
if you want, let me know what is the part number of your HVAC control.
i have another one laying around i can send you just to check if yours is faulty (from a 01. so it might not fit).
another option is the ignition switch. any other strange behavior with the electric in the car?
