Old 09-02-2012, 08:36 PM   #1
DIY extremist
black_box's Avatar
Squeal Solved --- sort of embarrassing, $700 lesson in diagnosis....
So after going through hell and ripping out most of my hair, I found the issue that was causing all of the grief with my car (actually the 3rd issue on the clutch/IMS job). I was hitting my wit's end and took a diagnostic step that I should've done from the beginning.
I started listing on paper every conceivable way my car could be doing what I observed (loud squeaking from right-hand cylinder bank under engine load) with no regard to what I thought were known good parts, ranked them in order of difficulty to check, and then started down the list.
Even though I thought the noise was metal on metal or metal on plastic, I checked the spark plugs first. Turned out the #6 was a half turn shy of tight. How this happened I don't know, because I hadn't messed with them on this job.
I wish I'd done this first, instead of tearing out the transmission again and spending
$700 on a new flywheel and bearings!
Thanks to everyone who commented and gave suggestions as to how to find the problem. It's great having such a knowledgeable community of porschephiles to rely on for help.
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
black_box is offline   Reply With Quote
Old 09-02-2012, 08:57 PM   #2
Porsche "Purist"
Paul's Avatar
Congrats in finding it, reminds me of a problem I had with the gas pedal stopping to work whenever it felt like it.
1987 924S. 2002 996TT. PST-2
Old 09-03-2012, 05:20 AM   #3
Crap I completely forgot about these cars doing that! Glad you found it!
87 944S brought back to life
Dragonwind is offline   Reply With Quote
Old 09-03-2012, 07:48 AM   #4
BruceH's Avatar
Glad you found the problem! Off topic, I see you added Bluetooth to your CDR 220. What kit did you use? I am still trying to decide what to do about that. Thanks.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 09-03-2012, 08:47 AM   #5
DIY extremist
black_box's Avatar
I used one of these: HQRP Audio cable Blaupunkt to 3.5MM fits Porsche Becker CDR-22 CR-220 CDR-220 on eBay! for input to radio, and then an aircast auot to get the BT signal (Belkin : AirCast Auto HandsFree).
Sound quality is great with engine off, but there's a bit of ignition noise that I have yet to filter out.
Old 09-03-2012, 08:54 AM   #6
ccjazz's Avatar
I've been following your threads with interest black box. Really happy to hear you found your problem.
'01 Boxster S (purchased new) triple black, litronics, cruise, heated seats,18's.
ccjazz is offline   Reply With Quote
Old 09-03-2012, 12:33 PM   #7
katanihouse@shaw.ca's Avatar
I've been following your threads as well BB as Iv'e got the same squeak. As I've told you earlier I've changed serp belt and next thing shop thought was water pump. Good thing I haven't got around to changing it yet. Thank you for all your posts and I hope your squeak free now!!
katanihouse@shaw.ca is offline   Reply With Quote
Old 09-03-2012, 01:31 PM   #8
Bruce Wayne's Avatar
great new BB !
glad to hear it's all come out good in the end.
:dance:
986 x2 6sp
2x Range Rover Vogue 4.6
2004 MX5 Sport 6speed Strato Blue (wifelet)
2x Range Rover Classic & CSK
Bruce Wayne is offline   Reply With Quote
Old 09-04-2012, 06:24 AM   #9
98 Arctic silver 986
tommy583's Avatar
I wanted to ask if you checked the plugs. The reason i didn't is because you didn't say anything about messing with them. So i figured i'd just come off as a moron. I'm glad you found your problem though. I had a loose plug this spring. It was the last thing i would have thought would be making a noise. Mostly because i just had the shop put in new ones. But since i never had a noise before i got the new plugs Ghost rider suggested i look there, low and behold he was right. Free fix.
Old 09-04-2012, 06:55 AM   #10
I have never encountered this. My brother old Mazda 626 used to throw plugs pretty regularly. What about a loose plug actually causes a squeak?
shadrach74 is offline   Reply With Quote
Old 09-13-2012, 06:47 PM   #11
Want to thank you Black Box finally got around to checking plugs today and guess what? The squeal is gone #1 was loose. Thank you for posting thread and finding solution your a life saver.
Old 09-14-2012, 12:52 PM   #12
DIY extremist
black_box's Avatar
hahaha, it's always gotta be something that makes you feel dumb in the end, right? Glad you got your Porsche back in shape, now go drive!
Old 09-15-2012, 03:48 AM   #13
hi, I was following your struggle on another forum, tomk, and am amazed at the root cause, who would have thunk it. i've been a DIY guy for over 30 yrs , have a pretty extensive shop with a lift and I have to say that this one would have completely fooled me ! So, in the end you solved it, and your diagnostic skills have likely improved, even if you have an unneeded flywheel. i hope you get to enjoy your car now
oldboxster is offline   Reply With Quote
Old 09-27-2012, 11:02 AM   #14
Do you have the stock dual mass flywheel as an extra. I've been running lightweight for awhile and tired of he racket I'm not going to do anything Intil I need a clutch but I wouldn't mind picking one up
2001 Boxster S 3.6, 2003 E46 M3, 94 968 Cab, 80 911 Weissach Edition, BMW 1200 CLS
smshirk is offline   Reply With Quote
Old 09-27-2012, 11:18 AM   #15
DIY extremist
black_box's Avatar
PM sent, smshirk
Old 09-27-2012, 11:23 AM   #16
I have a similar squeak...will check the plugs.
Thanks for the work and info!
Old 09-27-2012, 12:08 PM   #17
DIY extremist
black_box's Avatar
My boxster seems unusually prone to this type of problem... Solution is to use a torque wrench to tighten plugs, which I've never done with any other vehicle. Previously, I alway just got them finger tight, and then just a little more.
Old 09-27-2012, 12:59 PM   #18
Engine Surgeon
smshirk,
I told ya so!
Anyway, grab that flywheel and we can match the balance to your 3.6 FSI engine when the clutch is replaced :-)
US Patent 8,992,089 &
US Patent 9,416,697
