Old 09-02-2012, 07:36 PM   #1
black_box
DIY extremist
black_box's Avatar
Squeal Solved --- sort of embarrassing, $700 lesson in diagnosis....
So after going through hell and ripping out most of my hair, I found the issue that was causing all of the grief with my car (actually the 3rd issue on the clutch/IMS job). I was hitting my wit's end and took a diagnostic step that I should've done from the beginning.
I started listing on paper every conceivable way my car could be doing what I observed (loud squeaking from right-hand cylinder bank under engine load) with no regard to what I thought were known good parts, ranked them in order of difficulty to check, and then started down the list.
Even though I thought the noise was metal on metal or metal on plastic, I checked the spark plugs first. Turned out the #6 was a half turn shy of tight. How this happened I don't know, because I hadn't messed with them on this job.
I wish I'd done this first, instead of tearing out the transmission again and spending
$700 on a new flywheel and bearings!
Thanks to everyone who commented and gave suggestions as to how to find the problem. It's great having such a knowledgeable community of porschephiles to rely on for help.
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
black_box is offline   Reply With Quote
